Twincharging discussions.
spikes
Re: Twincharging discussions.
Postby spikes » Tue Jun 26, 2012 8:11 pm
NitroDann wrote:Come on then, give me a spec sheet for internals on a BP4w build as you would do it.
Do it.
I remember reading a 800RWHP BP on Miataturbo not too long ago, I'll have a look for it.
Postby NitroDann » Tue Jun 26, 2012 8:12 pm
Its a drag car.
spikes
Postby spikes » Tue Jun 26, 2012 8:19 pm
NitroDann wrote:Its a drag car.
Yeah that's it, could be some useful info about a strengthened crank perhaps?
deviant
Postby deviant » Tue Jun 26, 2012 11:15 pm
This car? http://www.globalnetspace.com/miata/
Uses these internals: http://www.flyinmiata.com/index.php?dep ... 0%20A-BEAM
Dann needs a machine shop and a massive block of steel delivered :lol:
All this talk of superchargers...Dann....finish my exhaust so I can plan the next mod!
Postby NitroDann » Tue Jun 26, 2012 11:37 pm
Hi james,
The jig for building your exhaust was done today, unfortunately a lot of my day was wasted by driving to a business that isnt at its old location, and is listed at the wrong place still. Bastards.
Anyways, I have the only SE in the country with a set of race extractors on it right now and an SE exhaust on the floor with all sorts of bits welded to it for a jig haha. Ill continue it tomorrow evening.
deviant
Postby deviant » Tue Jun 26, 2012 11:58 pm
No worries Dann; just poking at ya. I know you have your shiz together :)
But seriously. Rotrex, 10psi, big injectors, intercooler, ecu and nitro spec exhaust.........
Postby NitroDann » Wed Jun 27, 2012 12:21 am
You will rotrex it?
My god man, you gotta tell me this stuff before I design your exhaust!
deviant
Postby deviant » Wed Jun 27, 2012 12:27 am
Just a whimsy thought in the last 5 minutes :lol:
Not really something I have thought much about to be honest, I'm happy with keeping the simplicity of N/A at the moment and having to drive the tyres off it to get anywhere quickly.
Carry on as you are :D
wozzah1975
Postby wozzah1975 » Wed Jun 27, 2012 11:31 pm
Do it.
Hi mate, missed this post!
For a start, I'd just supercharge it and see how that travels, maybe even start with an SC14.
Forged pistons and rods, ARP mains and head studs. Big valve head, ported of course. I'd run big comp and E85, maybe even 10-1 or more, and about 10lbs boost for a start, then once it's sorted keep upping it, maybe 15-20lbs. Cam wise, probably something over the .400" mark, 280deg advertised and 240@50ish. Inlet wise, a custom plenum style unit with tapered runners and bellmouths inside it, and a decent throttle body, 60mm ish. I'd run injectors in the std spot, and a second set pre-charger with a staged system and see how that went. BIG pipes, probably 2" primaries, but still put some thought into the lengths.
Woz
Users browsing this forum: No registered users and 213 guests
