I understand there was a change in the design between the short nose and long nose B6 motors, but is the front pulley on a BP interchangable with a later model B6?
Such as: http://www.miatamania.com/Shop/ViewProducts.aspx?PlateIndexID=77379
Crank pulley: will a BP fit a later model B6?
- jerrah
The following, if accurate, suggest it would:
http://cgi.ebay.com.au/NEW-LIGHT-WEIGHT ... 286.c0.m14
http://cgi.ebay.com/ebaymotors/Mazda-Mi ... 06.c0.m245
- de Bounce
I have no positive idea if the pulleys are interchangeable!
However I believe that each pulley is unique to the type/model of engine due to crank dimensions and drive belt styles.
Seen a youtube video by Mike King where he describes the the different versions
Linky
He starts getting into it after about a minute.
Hope it helps
Linky
Hope it helps
