Throttle bodies and Superchargers
jerrah
Postby jerrah » Sun Dec 13, 2009 10:20 pm
Why do they mount the throttle body to the supercharger in a hotside supercharger setup?
Surely you would get better throttle response leaving it on the intake manifold but I'm guessing there is more to it than that?
1991 MX5
Juffa
Postby Juffa » Sun Dec 13, 2009 10:47 pm
I'm not sure what you mean. Can you clarify using the following pic of a hot-side install?
Or this cold side install
Better yet, here is some 3d rendering of the FFS coldside.
http://www.fastforwardsuperchargers.com ... harger.htm
J
jerrah
Postby jerrah » Mon Dec 14, 2009 12:01 am
The pictures don't clearly show the throttle body because it has been removed and is sitting on the back of the supercharger.
In the JRSC picture it's using the dummy throttle body on the intake manifold.
1991 MX5
Postby 93_Clubman » Mon Dec 14, 2009 12:14 am
There's some discussion in the bottom third of the following page on Danny's JRSC'd NA:
viewtopic.php?f=57&t=29490&start=90
jerrah
Postby jerrah » Mon Dec 14, 2009 11:24 am
Thanks for that, especially the miata.net link http://forum.miata.net/vb/showthread.php?t=203287. It would be a superior method of running the supercharger if the boost spike could be managed.
1991 MX5
Postby 93_Clubman » Mon Dec 14, 2009 12:06 pm
From memory at least one forumite is running a twin throttle cables & TB setup - might have been tedsmx5?
jerrah
Postby jerrah » Mon Dec 14, 2009 4:42 pm
From what I've read on miata.net they suggested that at stock pressures on the M45 the release valve could handle the pressure stock. With a higher pressure pulley they installed a blow off valve on the supercharger with good results. It certainly sounds easier than running two throttle bodies and throttle cables.
The downside apparently is with the TB on the intake manifold the supercharger sounds like 'mad max'. I'm not exactly sure how loud they mean by that.
1991 MX5
greenMachine
Postby greenMachine » Mon Dec 14, 2009 9:41 pm
jerrah wrote:From what I've read on miata.net they suggested that at stock pressures on the M45 the release valve could handle the pressure stock. With a higher pressure pulley they installed a blow off valve on the supercharger with good results. It certainly sounds easier than running two throttle bodies and throttle cables..
... and watch the pressure spike kill the i/c :shock: :x
Of course, if you are not running an i/c, you probably don't have the boost to do that sort of damage anyway. Search the big forum, there is plenty of info over there, this has been looked at pretty closely by some people who have tried some very interesting stuff, look on the M62 and twin screw threads ... .
jerrah wrote:The downside apparently is with the TB on the intake manifold the supercharger sounds like 'mad max'. I'm not exactly sure how loud they mean by that.
VERY loud! :shock: See the same threads mentioned above, look for the video with audio, it is a magnificent noise, but not one to live with.
:mrgreen:
timk
Postby timk » Mon Dec 14, 2009 11:06 pm
I find the throttle response no worse than stock really... throttle body relocated to the back of the blower.
jerrah
Postby jerrah » Mon Dec 14, 2009 11:22 pm
You'll have to show me your latest supercharged car sometime.
1991 MX5
