hey guys just after some info.
1- when u have fitted a larger intercooler obviously you have to modify the standard intercooler pipes- i just need to know hve you trimmed the pipe where it connects to the cooler or have you cut a section out further along and welded it together? i ask because i was wondering if trimming the section which the rubber pipe grips to will allow the rubber to blow off easily?
2- does anyone have a factory cast dump pipe they would like to sell?? or an aftermarket one the bolts up to the turbo??
thank u
Questions for SE owners
- travyMX5
- Hammer
I know MX5 Mania has done this to several SEs now, so there will be a good chance one of those are in this forum. But if you don't get an answer, give David at MX5 Mania a call.
- blackster
travyMX5 wrote:hey guys just after some info.
Search function is your friend.
viewtopic.php?f=29&t=23738&hilit=intercooler
travyMX5 wrote:2- does anyone have a factory cast dump pipe they would like to sell?? or an aftermarket one the bolts up to the turbo??
Daniel had few OEM casts at his place, pm little deckers. He may be prepared to sell you one.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
- CT
Just cut the pipes and slowly weld a little bead on the end of the pipe at low temp - mig or tig is better than stick on this thin stuff. Daniel will mostly have SP cast dump pipes - I doubt he'd have too many SE ones lying around.
- blackster
CT wrote:I doubt he'd have too many SE ones lying around.
Wasnt there that long ago and had wrecked a few SE's, he had a few OEM manifold and short cast dump pipes, lying around.
Previous
04' MX5 SE.
02' MX5 Classic ed.
04' MX5 SE.
02' MX5 Classic ed.
Users browsing this forum: No registered users and 229 guests
