NC GEARBOX
Technical Guides primarily to do with the NC series
Hurricane
Vehicle: NC - LE
NC GEARBOX
Postby Hurricane » Sat Jul 03, 2021 9:47 am
Hi all, just some advice I have a 2005 Limited Edition manual NC with 124,000klms that seems to be stiff getting into 2nd gear when cold. Once it is warm it’s ok. Read an article on Nulon Smooth Shift has anyone tried this. Cheers
2005 Limited Edition Velocity Red with plenty of bling.
Re: NC GEARBOX
Postby 93_Clubman » Sun Jul 04, 2021 1:00 pm
Yes have used it along with Nulon GB oil in an NA with good results - slowpoke on here also used it along with Nulon GB oil in his 10AE & swore by it. Not sure what GB oil you're currently using but from JBT & Regie's posts, who are both NC1 owners:
JBT wrote:Nulon do a GL4 synthetic. I'm using that in the NC and it's fine.
Regie wrote:I'm using Nulon GL4 oil for my gearbox, smoothest shifts I've ever had
JBT wrote:I'm using Nulon GL4 in the NC and it works a treat with no cold baulking into 2nd etc. https://www.nulon.com.au/products/gear-and-differential-oils/full-synthetic-75w-85-smooth-shift-manual-gearbox-and-transaxle-oil
More detail from JBT & Regie:
viewtopic.php?f=29&t=75633&hilit=nc%2A+gearbox+oil
viewtopic.php?f=29&t=72915&hilit=nc%2A+gearbox+oil
Hurricane
Vehicle: NC - LE
Re: NC GEARBOX
Postby Hurricane » Sun Jul 04, 2021 2:31 pm
Thanks for the info.
madmort
Re: NC GEARBOX
Postby madmort » Sun Jul 04, 2021 7:49 pm
I've got Castrol Syntrax ?( not sure of spec) in my NC1 at the minute and trying to sort out 1st to 2nd shifts, still find it notchy when cold.
Going to try Redline MT90 shortly and see how that fairs, I've read good reports from the USA for reducing 1st to 2nd issues.
When warm no problems with shifting at all, I'll report back after the Redline fill.
2002 NB Titanium (sold), 2006 NC1 (sold), 2023 ND GT (sold), 2025 35th Anniversary Edition
greenMachine
Re: NC GEARBOX
Postby greenMachine » Sun Jul 04, 2021 8:57 pm
The Redline is popular in the NB 6-speeds for resolving shifting issues. I am pretty sure that is what is in mine now, I've used in both road cars and the racecar.
:mrgreen:
Luke
Re: NC GEARBOX
Postby Luke » Mon Jul 26, 2021 9:50 pm
I have Ford Motorcraft in my NC that the yanks all rave about.
Forget the exact name but in Australia it is labelled as for Ford Focus or Escape manuals.
From the factory manual for a NC.
API Service GL-4, SAE 75W-90
The above is why I did not go Nulon, as that is 75W-85.
I do a lot of track work and going to lighter oil in the gearbox did not add up to me.
Like all the advice has already pointed out, don't put in GL5, 6 or combo GL4/5.
They are different oils for a different purpose, not a better spec.
2022 BRZ 10AE
2021 GR Yaris
Return to “NC [2006 +]”
