NC Brake Job
Technical Guides primarily to do with the NC series
Red Baron
NC Brake Job
Postby Red Baron » Tue Feb 24, 2009 7:19 pm
Hi Guys,
Fronts are a walk in the park.
Rears, anyone done the rears?
I am thinking that I need to back off the handbrake to get the piston back.
Anyone done the job and have a comment?
baron
Red
True Red NC Touring, Tein's, sways, beatrush chassis suite, roadstersports exhaust, starting to steer like a sports car, and stop like a bee with Hawk pads and DBA4000's! And still the wife's shopping cart, "Gold"
JBT
NC Brake Job
Postby JBT » Tue Feb 24, 2009 7:47 pm
There is a fair bit of info here.
IMMX5
NC Brake Job
Postby IMMX5 » Tue Feb 24, 2009 11:03 pm
Haven't had to replace the rears but have removed them when having a brake problem a while back.
Retract the piston by rotating them - would imagine clockwise to retract. From memory only retract as much as you need to fit the new pads bearing in mind each 1/4 turn is a fair bit. You also need to ensure the cruciform orientation is maintained - there is a locating 'stub' on the rear of the pad squeal shim. The brakes should self adjust with application of the handbrake.
2006 True Red 6 Speed - stock currently... (Still!???)
Garry
NC Brake Job
Postby Garry » Wed Feb 25, 2009 8:56 am
One of my other cars used that system. Gen2 RX7 maybe?
Red Baron
NC Brake Job
Postby Red Baron » Wed Feb 25, 2009 8:14 pm
Thanks guys, it all makes sense now.
baron
Red
JBT
Re: NC Brake Job
Postby JBT » Sun Mar 04, 2012 11:19 am
The repair manual indicates an SST should be used to rotate the piston - see attached. What have others used to rotate the piston? Will any flat plate e.g. a flat file end do the trick?
Charlie Brown
Re: NC Brake Job
Postby Charlie Brown » Tue Mar 06, 2012 9:31 pm
I just use a broad flat chisel to rotate the piston back in.
Tip: Pump the brakes before you pull the hand brake on. I found the brakes bound if I did it the other way around.
JBT
Re: NC Brake Job
Postby JBT » Wed Mar 07, 2012 6:29 am
Thanks CB. Did you need to disconnect the handbrake cable at the caliper when changing the rear pads?
JBT
Re: NC Brake Job
Postby JBT » Wed Mar 28, 2012 6:51 am
Discussed this with CB off-line and have now successfully completed a front and rear pad change. No need to remove the handbrake cable.
Return to “NC [2006 +]”
