The ABS light was on and no codes were read with a reader, fluid level was on the high mark. Resetting the ECU by disconnecting the battery also failed to clear the ABS light.
Luckily I had Daniel Deckers on hand to offer advice which was, clean the rear ABS sensors.
This is a very easy job. The rear sensor is held in position by one 10mm bolt on the rear hub.
Undo the bolt, pull out the sensor, it’s magnetised, check for metal filings standing out from the sensor.
If the filings are there, grab a cloth and wipe/pinch them off. Reassemble. Job done.
The front sensor is on the inside face of the hub and doesn't seam to be made from the same magnetised material but a check once in a while would still be a good idea.
It’s probably worth while checking the sensors at every pad change. It has taken 160,000 kilometres for this problem to occur on my car but it’s not fun flat spotting V70A’s. They’re not cheap.
