Mx5 SE 1 to 1 gear
Technical Guides primarily to do with the NB series
mk
Mx5 SE 1 to 1 gear
Postby mk » Tue May 26, 2020 3:06 pm
Just wondering what would be the 1.1 ratio (what gear) it would be on stock SE
I’m assuming that the 6 speed is the same ratio as others and know that they run 3.6 diff ratio
Thanks Peter
ManiacLachy
Engaged
Re: Mx5 SE 1 to 1 gear
Postby ManiacLachy » Tue May 26, 2020 3:25 pm
5th is your 1:1 gear.
Yes, the SE transmission is the same ratio as the other NB 6-speeds, and a 3.6 diff in the back as per the others, but its got different axles and all SE diffs are LSDs.
There's some talk about stronger internals in the SE 'box, shot-peened gears or something. But I personally don't believe it, I have never seen evidence of it, and have heard of them breaking at about the same point as normal NB 6-speeds.
mk
Postby mk » Tue May 26, 2020 4:28 pm
Thanks for the fast response
So even with the 3.6 diff ratio 5 is still 1 to 1
greenMachine
Postby greenMachine » Tue May 26, 2020 4:38 pm
It is 1:1 between the gearbox input and output shafts, not between the input shaft and the driveshafts. That is, gearbox ratios.
:mrgreen:
Return to “NB [1998 - 2005]”
