Help required
Posted: Fri Apr 17, 2015 6:16 pm
I have had my 2002 NB at a Mazda service dept for the last 5 weeks whilst they try to sort a problem that is proving to baffle them and a Auto electrician. The car whilst i was driving just suddenly stopped i called a tow truck and had it taken to my residence where i pushed it into the garage and over the next few days tried to start it to no avail i did read the handbook which led me to think that the problem was to do with the immobiliser i arranged another tow to the dealer.They agreeing with me sent the immobiliser away to Melbourne for testing they said they found a loose wire resoldered it and sent it back, dealer reinstalled it started the car and it fired and still shut down. Since then they the dealer and Electrician have tested each wire running from the ignition to the engine and come up with this scenario if they run a screwdriver past the crankangle sensor and reinstall back into its position it starts and runs turn it off and on for 5/6 times then it goes back to starting and shutting down again.The dealer suggested i post this on the forum to see if anyone else has had this problem their suggestion at this time is for me to purchase a complete immobiliser and keys and try that at a cost of $500 plus the money spent to date about $450 and if this dont work im stuck with the part. Any ideas would be helpful im not mechanically minded and certainly dont get the electrics involved.
Thanks in advance for any HELP just want my NB back
