How to Install Midrange Speakers into an MX5 Door.
Technical Guides primarily to do with the NB series
Re: How to Install Midrange Speakers into an MX5 Door.
Postby Jeo » Thu Jun 17, 2010 5:30 pm
Write up is good, but you may want to loose the sig. Advertising by non-sponsor businesses isn't encouraged.
gobsmax
Postby gobsmax » Thu Jun 17, 2010 5:41 pm
nice...where did you get those A-Pillar from? Custom made? Available for the NA?
Red '91 NA6 (R.I.P.)
Black '07 NC PRHT (R.I.P.)
Gold '98 NB8A (SOLD)
Soul Red '15 ND 1.5 GT
Postby sliq » Thu Jun 17, 2010 5:54 pm
good write up 8)
philz
Wheel guru
Postby philz » Thu Jun 17, 2010 6:22 pm
Nice to have you on here Marty, your work is always of awesome quality!
This guide will be very helpful for fellow mx5 owners.
NMX516
Postby NMX516 » Thu Jun 17, 2010 6:36 pm
Fhrx, thanks for the write ups.
Do you have any clues on how to get new speaker cabling through into the doors? The NB's in particular are very difficult to access the "car side" of the factory plug which runs the cabling into the doors. Without drilling holes, I guess the alternative is to connect the amp to the factory speaker wiring and then mount the cross over in the door? Does that make much difference to sound quality, as opposed to heavy gauge wiring throughout? What would be the usual method you would use, or does it just depend on the customer as to whether they want larger cabling throughout?
Cheers.
Postby Hammer » Thu Jun 17, 2010 7:00 pm
gobsmax wrote:nice...where did you get those A-Pillar from? Custom made? Available for the NA?
+1 on the pillar mounted speakers. Very OEM look which I like.
Kav
Postby Kav » Tue Aug 11, 2015 9:42 pm
Hi All,
Does anyone know who Fhrx is? looking at upgrading the speakers in my SE, wanted to get in touch with him after reading his guide!
Also, would anyone know good audio installers that have worked on NBs before?
Cheers!
Postby Jeo » Tue Aug 11, 2015 11:20 pm
FHRX Studios.
booki89
Postby booki89 » Fri Jun 17, 2016 12:24 am
Probably a dumb question but....
What do you use as "gap filler"? What particular product and how is it applied? Smear it with your hand or put it on the spacer itself?
Postby hks_kansei » Fri Jun 17, 2016 2:55 pm
The gap filler looks to be just regular old silicone, or sikaflex.
Even if it's not, either of those will do the same job.
It comes in a tube and you apply with a caulking gun, then smooth with your finger.
the pic looks like it's been applied after the spacer is attached, but applying it beforehand and letting a little squeeze out would give a better seal (just makes it messier if you need to remove the spacer at a later point)
Return to “NB [1998 - 2005]”
