a 80mm long split near the top hose......and the sweet smell of boiling coolant in the air
So i looked on ebay and found an ASI 52 mm alloy rad for $300.....GG!
ASI rads have been proved to do the job very well by many nissan boys on the drift scene...... so i had no qualms about going the cheaper option,since i knew it was going to work fine.
So.....out with the old and in went the new.....
unplugged thermos, drained the coolant and pulled out the rad...
The thermos come off small first then big.....and go back on big then small, because they overlap....
The only annoying thing i can find with the rad it the drain plug is 25mm.....(not common in most spannner sets)
