Remove the screw on the door handle
And the vertical screw below the latch
Note : The later NB models have 2 screws on the handle bit instead
Next remove the clip near the 1/4 window, carefully use a knife to pop the top half of the clip outward
Once the middle bit has popped out, use pliers to gently pull the clip out
This is what the plastic clips look like
Remove the 2 clips near the door catch
Gently pull the bottom of the door skin so the plastic clips on the inside of the skin pop out of the door.
The inside of a 98 NB8A door
The inside of an SE door
Note: the locks on the SE door are actually about 2cm forward of the NB8A lock location.
