Na6 fuel pressure regulator stock pressure
Technical Guides primarily to do with the NA series
mk
Postby mk » Sun Jun 21, 2020 9:33 pm
I’m removing the standard na6 fuel pressure regulator and want to know what is the standard pressure it is on so I can drive it to get my tune
Thanks Peter
Re: Na6 fuel pressure regulator stock pressure
Postby 93_Clubman » Mon Jun 22, 2020 1:01 pm
'a good roundabout starting point is the stock range of 35-38 psi'
https://5xracing.com/p-13109-5x-racing- ... lator.html
Return to “NA [1989 - 1997]”
