lsa coils cant get tacho to work
Technical Guides primarily to do with the NA series
mk
Postby mk » Mon Jul 23, 2018 7:51 pm
I have recently got the lsa coils wired up and cant get the tacho to work
just wondering if anyone has a solution for me
im running a haltech plug and play
thanks Peter
Re: lsa coils cant get tacho to work
Postby 93_Clubman » Tue Jul 24, 2018 12:08 pm
For better visibility you might like to ask okibi to move your post to: 'MX5 Audio, Electronics & Lighting'
bartmanftw
Postby bartmanftw » Tue Jul 24, 2018 7:17 pm
More info would help, like specific model of your car as well as ECU.
I'm going to assume it's an NA6 though since later models should have the ECU driving the tacho. You'll need to wire a tacho output from the ECU to your gauge cluster. The LS coils do not have a tacho output inbuilt.
Return to “NA [1989 - 1997]”
