NA6 Variable TPS
Technical Guides primarily to do with the NA series
WhiteNA6
NA6 Variable TPS
Postby WhiteNA6 » Tue May 17, 2011 5:38 pm
hi there.
installing an adaptronic E420c in my na6.
i am told that i need a variable tps.
i also hear from other sources that this can be done diy?
if its easier or better even, replacing is also on the cards.
anybody know where i would get one of these "variable tps's"?
The Secret Weapon
timk
Re: NA6 Variable TPS
Postby timk » Tue May 17, 2011 8:04 pm
I used a BMW variable TPS on my NA, the write up is here:
http://ozmx5.com/viewtopic.php?f=4&t=27
WhiteNA6
Postby WhiteNA6 » Tue May 17, 2011 9:30 pm
Ah excellent, cheers sab
The Secret Weapon
Postby 93_Clubman » Wed May 18, 2011 11:40 am
tbro
Postby tbro » Wed Jul 06, 2011 8:33 pm
http://www.efihardware.com/products/880 ... twin-wiper
You can use this to fit a variable TPS to the std throttle body. Correct shape for shaft, will need some drilling and thread tapping but if you can't do that then maybe you should think twice about what your doing.
Terry
Return to “NA [1989 - 1997]”
