I was wondering if anyone knows how to wire in a automatic throttle body ( variable ) tps to a na6 with a on/off tps
ill be using a haltech 1000
thanks Peter
how to wire up a variable auto tb on a na6
Re: how to wire up a variable auto tb on a na6
If you're using an aftermarket ecu shouldn't it be as simple as just wiring whatever tps you have into the ecu and then doing the calibration on the ecu?
http://www.haltech.com/wp-content/uploads/2011/01/Platinum1000WiringDiagramrevJ.pdf
Or by automatic throttle body do you want a drive by wire throttle body?
Sorry for not telling the full story
I purchased a auto tb off a 92 mx5 na6
I'll be runing the plug in haltech
Aaaah a throttle body off a MX5 NA6 that was an auto...
You will need a suitable TPS.
Have you decided how it will be tuned?
He's talking about wiring the variable tps from an auto mx5 into his non variable tps on his manual na6.
Isn't it just 3 wires?
- Cus
If the plug fits, it might just be a matter of calibrating it in the ECU.
I used a VL Commodore one modified with instructions found in the Megasquirt Owner's Thread, it was easier than trying to find an auto TB + TPS.
Peter, do you have the plug and play haltech yet?
Like others have suggested, maybe you just need to calibrate it.
That's all I did with my MS2.
ill be purchasing the haltech next week
the plug on the auto tps is a 4 wire and plug is bigger
manual tps has 3 wire and a smaller plug
auto has green/black red/black red green/red
manual has green/white black/white red
- Cus
Here you go!
http://www.miataturbo.net/megasquirt-18/how-wire-analog-tps-ms-90-93-car-36271/
Option "B" would be to find a VL Commodore TPS and modify that - it uses the same plug so you're not hacking up the loom on the car.
Good work Cus.
From that thread it appears the op has a Na8 tps and not a na6 one. So the red wire is not used.
Since the plug has to be changed it may well be worthwhile pricing a vl commode one that just plugs in.
- Cus
As far as pricing a VL TPS, do the legwork to visit local wreckers, the ebay options are priced about $80- $120 more than they need to be!
