Can someone please tell me the correct part numbers for the genuine Mazda oil filter and air filter to fit a 2017 ND 2.0 litre.
Thanks
ND filter
- madmort
Re: ND filter
Best you go to Mazda Spare Parts and find out the current numbers as they change, current oil filter appears to be 1WPE-14-302 and air filter PEES-13-3A0 but I'd be confirming with Mazda.
2002 NB Titanium, 2006 NC1, 2023 ND GT
- bruce
- Vehicle: NA8 - Turbo
- madmort
Re: ND filter
I also think the new oil filters at least, are made in Thailand. The old part number I think PE01-14-302A (OEM) were made in Japan
- Learner Driver
Re: ND filter
The number on my current filter is BT1150107600 which doesn't come up on line so I was hoping that someone has done a filter change recently and can give me the information that I require.
- Learner Driver
Re: ND filter
Found this on google
There're now 3 OEM Mazda SkyActiv oil filters:
OEM Mazda
SkyActiv Oil Filters
PE01-14-302A Made in Japan with the best quality.
Comes with greased O-ring type gasket、
shrink wrapped seal on top preventing dust、
and packaged in a sealed paper box.
1WPE-14-302 Made in Thailand.
Smaller in outside diameter than PE01-14-302A.
and packaged in a non-sealed paper box.
PE01-14-302A-MV Made in Mexico.
Comes with non-greased flat gasket、
shrink wrapped seal on entire filter、
and no paper box.
OEM Mazda
and no paper box.
- madmort
- bruce
Re: ND filter
How hard is it to ring Mazda with your VIN. This is basic simple stuff.
- Vehicle: ND - RF
Re: ND filter
bruce wrote:How hard is it to ring Mazda with your VIN. This is basic simple stuff.
Mazda will not supply part numbers, only parts.....
Once you've bought the part from them you can then read the number from it!
- Vehicle: Non MX-5
Re: ND filter
We'd get the Thai one in oz.Bloggsy wrote:Found this on google
OEM Mazda
and no paper box.
- beavis
- Vehicle: NB8B - Turbo
Re: ND filter
As mentioned, there have been a variety of genuine mazda part numbers over time all suitable for the ND skyactiv motors.
This is what I have on the shelf, the two genuine items are different part numbers and one marked as Japanese made, the other Thai, but effectively interchangeable, the aftermarket one is some $5 cheaper, SolidAce are a UK brand.
And if you want one, I have them with me in Melbourne: https://beavismotorsport.com/store/nc-nd/maintenance.html
