Help please, boot lid jammed closed.
Will unlock ok with either key, remote or console cable, but won't open !
NRMA can't help, something is jamming the latch.
Any clues please ?
Jammed Boot lid. SE
- jezman
Jammed Boot lid. SE
Wakefield. SMSP GP: SMSP South: SMSP North: SMSP Brabham: Baskerville: MX5 heaven ! Symmons Plains: Winton: Sandown. Phillip Island (wow)
Re: Jammed Boot lid. SE
if no one comes up with any ideas you may need to see a panel beater.
im sure they deal with that sort of thing all the time.
Did you Google it?
NA with a jammed boot- a guy used a hole saw to get to the detached connecting rod between the key hole and the latch.
Did you Google it?
- NitroDann
If heavy things are in there they are probably against it.
Try slamming the brakes on HARD.
Seriously
Seriously
- davekmoore
Yep, and/or find a very steep hill.
- KevGoat
Maybe try pushing down on the bootlid while unlocking ...
edit: .... ummm ... not while going downhill, slamming the brakes on
- davekmoore
All of the above.
All usual disclaimers apply.
- jezman
Thanks gentlemen for the imaginative ideas
Solution was simple in the end..........
Squeezed the thin WD40 tube between the rubber seal and boot lid, gave it 10 minutes and it opened normally.
Note to self: lubricate catch regularly !
