strut tower brace torque specs
Posted: Thu Mar 05, 2015 5:52 pm
by Garido
Hi folks,
I have some front and rear mazdaspeed strut tower bracing I'd like to install. Anyone got an idea on torque specs. While probably don't as sensitive as rebuilding an engine or diff I don't want to destroy a thread or have them too loose.
Thank you all ^^
Re: strut tower brace torque specs
Posted: Thu Mar 05, 2015 7:15 pm
by Rolley
I reckon they will be the same as if the brace was not fitted so "Upper shock mount plate bolts" in the suspension section of this shoud work just fine.
http://www.miata.net/garage/torque.html
Luke.
Posted: Fri Mar 06, 2015 11:56 am
by hks_kansei
Same torque as stock.
It's not a lot of torque they need, I just wind them until they reach the bottom out, then do another 1/4 turn or so.
Posted: Fri Mar 06, 2015 1:08 pm
by Garido
Kind thanks to both for their help. Will let you know how I go but should be fairly straightforward.
Posted: Fri Mar 06, 2015 8:08 pm
by manga_blue
They'll work just as well with blutack.
Posted: Thu Aug 13, 2015 3:51 am
by r3395
Use a ring spanner 1 handed dont go crazy will be ok
