Oil sump washer replacement problem
Technical Guidance for doing those Tricky Jobs
in the making
Postby in the making » Sun Aug 03, 2014 4:26 pm
Hi,
I've just changed the oil for the first time on an NA6. There was no sump plug washer, so I put one on. Problem is I used a rubber O ring. Just read that it should be on of these. http://www.mx5parts.co.uk/sump-plug-washer-p-1087.html
Should I leave it or change it?
pezchops
Re: Oil sump washer replacement problem
Postby pezchops » Sun Aug 03, 2014 5:43 pm
do not use an o-ring for a sump plug washer.
o-rings are designed to be contained in a groove.
its not if it will fail, but when it will fail.
with heat from the motor and pressure from the sump plug the ring will fail.
i wouldn't drive that car anywhere like that if i where you
in the making
Postby in the making » Sun Aug 03, 2014 6:32 pm
Thanks. Of course you're right.
I knew as soon as I was done it was wrong.
