Help installing Ogura Racing Clutch (ORC)
Technical Guidance for doing those Tricky Jobs
sifoo
Postby sifoo » Sun Apr 06, 2014 9:54 pm
Hi guys
I got a ORC clutch assy and I'm not sure which the the clutch disc should face so I thought I'd get some help first. Here is what the disassembled clutch looks like:
For easy reference I've labelled the clutch disc 'side A' (shorter spline) and 'side B' (longer spline).
Here's what it looks like sitting on the flywheel:
Side A:
Side B:
Obviosuly I need to get this right the first go or the car won't get into gear meaning I'll have to pull it all apart again which I don't want do! So which is the correct way of installing this clutch?
Thanks for your help!
Paul - Eunos Roadster NA8
deviant
Re: Help installing Ogura Racing Clutch (ORC)
Postby deviant » Mon Apr 07, 2014 5:29 am
It normally says on the clutch friction plate 'this side to flywheel' or something similar.
