Air cleaner
Technical Guidance for doing those Tricky Jobs
Magnum
Air cleaner
Postby Magnum » Wed Oct 23, 2013 1:58 pm
Hi all,
I'm thinking about swapping the standard air cleaner in my 07 NC for a performance one. Mainly for looks and sound, but also hopefully a few extra ponies.
Can anyone recommend one that is easy to install (i'm not much of a mechanic), reasonably priced, available in oz and good looking?
The K&N 57i looks pretty good, anyone swapped one of these out? what is it like? where did you get it and how much did it cost?
thanks guys.
M
ph
Re: Air cleaner
Postby ph » Wed Oct 23, 2013 2:30 pm
Mx5parts in the UK sold me a K&N one for the NB with brackets to fit on the engine bay very easily, so if it's as easy for the NC, I would recommend going there.
Some problems, are so complex that you have to be highly intelligent
and well informed just to be undecided about them
TTT
Re: Air cleaner
Postby TTT » Mon Dec 09, 2013 4:29 pm
ok?
chrisearl88
Re: Air cleaner
Postby chrisearl88 » Mon Dec 09, 2013 10:32 pm
Will not change the sound, not will it add any ponies unless your old filter was really really dirty. Look at getting a cold air intake, checkout one of our forum sponsors mx5mania.com.au
Re: Air cleaner
Postby hks_kansei » Mon Dec 09, 2013 11:09 pm
chrisearl88 wrote:Will not change the sound
I'm pretty sure it will.
If you remove the airbox and panel filter and replace it with an exposed pod like the 57i you'll hear it.
