Fitting LHD OEM criuse control to a RHD 90 NA
- Hammer
Re: Fitting LHD OEM criuse control to a RHD 90 NA
Great stuff.
- Tedsmx5
- Vehicle: NA8 - Supercharged
"Since I could not find a steering column stalk with the resume/accel-set/coast switch in it, I used a small toggle switch with a spring return (on-off-on) to centre and mounted it in a spare switch location next to the dash light dimmer".
You can get them from the US but the lights and wiper controls are reversed left to right.
Ted
ps. Very well done, I'm going to use a VN cruise control as they are small all in one and use a stepping motor, you run short of under hood real estate when you use forced induction.
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
- zossy1
Epic post! This is genuinely useful info, though I have to say cruise control is well down on my list of priorities
