xforce vs town & country exhaust
- funmx5
Re: xforce vs town & country exhaust
join the ballarat chapter of the mx5 club ,then you will here the t&c exhaust in convoy!!!!
red na6
cx7
cx7
- Mr nanotech
They are the same.... Tnc use xfirce muffler sections. The only difference is one is off the shelf stainless cat back and the other is custom made press bent mild steel with a chrome tip welded over the end.
Colin is a great workman and is very flexible so dont get my next comment wrong:
I would go the stainless xforce cat back. Its cheaper and its made for the car so bolting up is dead easy. As its factory made you can sell it off without losing much cash if you hate it too.
I own a tnc and removed it for another exhaust but recently took it back off for the tnc again.
Its a good exhaust but for value sake, def get the prebuilt since ots going to be the same anyway it terms of sound. The added bonus is that it will be mendrel bent and stainless unlike the hand made.
- NitroDann
But stainless sounds worse than mild.
- Mr nanotech
^^ Point taken
Price up an Xforce stainless cat back and print it off. Ring up Town and Country Exhausts and ask if they will do a similar system in mild steel mandrel bent with a similar tip for the same price.
- CrazyRacer
I recently rang an xForce distributor to enquire about getting a system and they told me they no longer use the complete xForce system on MX5s because the fit not great. Said they use the xForce rear muffler section and custom make the rest.
I ended up going with a T&C system, which I'm happy with.
