Hard top side striker plate install
Technical Guidance for doing those Tricky Jobs
Postby Jeo » Sun Jun 14, 2009 6:33 pm
Tools needed: Dremel, star head screw driver (no idea what its actually called).
Time taken: 15min
Difficulty: Trained chimp accessible
1. Mark holes where bolts need to go
2. Drill holes for bolts and progressively make holes bigger until the striker plate fits. I started with the cutting tool, then eventually worked up to a small grinding tool. This is only a halfway done photo, you will need to clean off the burred bits.
3. Bolt striker plate into place
Tada!
bensale
Postby bensale » Sun Jun 14, 2009 6:38 pm
If you are uncertain where to cut the hole you can pull the plastic trim off and on the other side there is a guide imprinted into the plastic showing where to cut :wink:
www.othersideproductions.com
Re: Hard top side striker plate install
Postby sliq » Sat Jul 10, 2010 10:02 am
dinosaur bump. novice question. if i am getting a brown davis roll bar, will it interfere with the OEM side latches for hard tops?
Alex
Postby Alex » Sun Jul 11, 2010 1:23 am
sliq wrote:dinosaur bump. novice question. if i am getting a brown davis roll bar, will it interfere with the OEM side latches for hard tops?
Nope.
Postby sliq » Sun Jul 11, 2010 7:57 pm
thanks man. i tried to go thru that thread with you installing the sparco but couldn't find any clear pics :lol:
