Help needed for a new owner
Posted: Sat Feb 28, 2009 3:59 pm
by zombie
Hi DJL, welcome to the forum, and welcome to the obsession!
I have not had this problem with my MX5, but had it constantly when I first purchased my previous daily driver (2004 Charade) - it drove me nuts so I know how you feel
The solution with the Charade was to change the angle of the fuel nozzle, so rather than the handle / lever pointing straight down towards the ground, it pointed at 90 degrees, towards the back of the car - when filling I would end up standing behind the car, not next to it. Once I started doing that it worked every time.
I suggest you try rotating the nozzle at various angles and try one that works for you and your car. Try different petrol stations also, if possible.
Posted: Sat Feb 28, 2009 4:13 pm
by Woo
Good points Zombie.
Might sound like an err der statement, but be sure to insert the nozzle all the way in past the flapper door inside the filler. Mrs Woo didn't realise and it took her 15 minutes to fill the 3 for the first time.
Bazz
Posted: Sat Feb 28, 2009 4:37 pm
by Fuzzlet
Lift the filler out a little?
Posted: Sat Feb 28, 2009 5:41 pm
by JBT
There's a problem with the filling tube/vent then. Check for obstructions.
Never had a problem with our NA in the past or the NC now.
Posted: Sat Feb 28, 2009 8:58 pm
by Hammer
Welcome to the forum and the 5 family.
This might sound like a stupid question...but is this happening on all pumps? Or have you been using the same pump from the same Servo?
I don't have this problem in my cars, but my local servo has one pump that is very sensitive and does what you describe - no matter which car I fill up. So I just avoid that pump when I can.
Posted: Sun Mar 01, 2009 12:43 am
by Okibi
DJL, welcome to the obsession, please update your profile so we know what city you're in. It assists us to point you in the right direction should you need any help.
Posted: Sun Mar 01, 2009 10:43 am
by xatz
This happened to me for the first time in my 5 the other day, I just angled it a bit more like people have said and it stopped.
It used to happen fairly consistently with my Mira, a couple of times I just had to go by feel on how much the tank would take (and would always underfill) cause I'd hold it and it'd click, then click, then click, etc... If I know a pump is good I just try to use that one all the time at the servo to avoid this. The pumps at these places didn't happen to be old or in a high use petrol station did they? The pumps that have done it to me have either been a little on the tatty side or in a position where they are used pretty much constantly all day.
Posted: Sun Mar 01, 2009 11:07 am
by Okibi
http://www.miata.net/garage/tsb/sb007_99.pdfAussie mazda dealers don't tend to fix these issues unless you badger them about it, perhaps yours hasn't been fixed.
In the US they fix them all the time because they have better "lemon laws".
Apparently the NC have an updated fuel filler "service bulletin" as well.
Posted: Sun Mar 01, 2009 2:41 pm
by Okibi
They don't do a recall unless it's an item that's going to kill lots of people.
I'd take that US recall with you and ask your Mazda dealer to look up your VIN number and see if it was already changed under warranty, I suspect not.
They will argue that's it's on there for years without the owner complaining so it's hardly faulty.
You might be able to get a discount on labour as it was a part listed as "faulty" by Mazda.
Posted: Sun Mar 01, 2009 5:52 pm
by Woo
DJL,
If you want me to have a look at it for you, shoot me a PM, I'm just up the road from you.
Bazz
Posted: Sun Mar 01, 2009 6:11 pm
by Okibi
Don't let Baz bring his MX-5 around you might get jealous and spend a small fortune trying to keep up
Posted: Mon Mar 09, 2009 6:06 pm
by Jeo
Good to hear its sorted.
And yes, all of those things are mandatory
Posted: Wed Mar 11, 2009 9:26 pm
by NMX516
So what were Baz's suggestions??
Re the fuel filler problem I mean, not the fuel useage problems
Posted: Fri Mar 13, 2009 8:18 pm
by NMX516
Simple yet effective!
