Oil Filters
Technical Guidance for doing those Tricky Jobs
Oil Filters
Postby Okibi » Sun Mar 16, 2008 6:16 pm
1red5 wrote:There are 2 different size filters, the smaller ones are technically for various Mazda's and Ford, the bigger ones are for various Hondas, but they are 100% compatible.
Since I found out, I have always used the bigger ones. I figure the bigger the filter, the bigger the filtering medium, the faster/easier the flow.
1red5 wrote:Dimensions are 80mm wide, 75mm tall.
Considerably bigger than the other one.
1red5 wrote:The bigger filter's part#'s are"
Valvoline = VO5
Ryco = Z79A
PureOne = PL14459
Ryco# Z436 is for the smaller filter.
wun911 wrote:I drive an NB8B and I have a mazda oil filter with B6y1-14-302AUS.
madboy
Oil Filters
Postby madboy » Thu Apr 23, 2009 5:58 pm
I recently pulled a Z411 filter off my 5, same diameter as the Z436 but about an 1.5 inches deeper, cleared the bracket infront of the filter by about 5mm when screwed out.
Z411 possibly has the same filtration are as the Z79A, but the Z79A being shorter and fatter seemed like an easier option for installation/removal
I think we found the Z411 listed under 323, not sure what years
wtnmiatas
Oil Filters
Postby wtnmiatas » Fri Jul 31, 2009 6:30 pm
My wife has a 06 Honda Element which has the long oil filter that also fits my 01 Miata. I buy the OEM Honda ones in bulk off Ebay & used them on both our cars now. Before on my 01 I use the OEM oil filter for a Mazda Millenia which was the longer one. But couldnt find them in bulk at a good price. I have cut both open to see what they look like inside. The only differents I see is the Honda has a different type oil by pass set up than the Mazda ones. Have little to none lifter noise at start up with either oil filter the Mazda or Honda. With other brands I did on the Miata.
91 BRG - 5sp - Life is too Short not to have Fun and Enjoy
