My thoughts on LEGAL Turbo engineering (NSW BASED)
Technical Guidance for doing those Tricky Jobs
mattywood
Re: My thoughts on LEGAL Turbo engineering (NSW BASED)
Postby mattywood » Sat May 19, 2012 12:37 am
any luck with an engineer?
Sean
Postby Sean » Sun May 20, 2012 12:57 pm
mattywood wrote:any luck with an engineer?
Athol Mullins is in the process of sorting out getting on the NCOP list.
He was always very friendly and open with advice under the old scheme.
My understanding is that he was just waiting for some amendments to his insurance to be approved by the RTA or whoever and he'd be on. It may have alrady happenned by now.
You'd do much worse than giving him a call.
Postby NitroDann » Sun May 20, 2012 1:15 pm
I was told last night that he is currently not taking on any new clients at all. Whatsoever, not even a wait list.
Sean
Postby Sean » Sun May 20, 2012 1:29 pm
NitroDann wrote:I was told last night that he is currently not taking on any new clients at all. Whatsoever, not even a wait list.
His definition of new clients may be looser than you expect 8)
Postby NitroDann » Sun May 20, 2012 1:33 pm
Maybe he just doesnt want to touch my mates s14..
Its pretty stock as far as engineered cars go.
Ecu exhaust injectors manifold turbo front mount.
Sean
Postby Sean » Sun May 20, 2012 1:42 pm
Young guy in S14 with typical dorifto mods...
Like I said, he's thorough...
I beleive the new customer limitation is not his choice, but part of the new scheme (could be wrong).
I suspect if you were using a shop he had on the books, he might be more interested, all assumptions from my conversation...
Postby NitroDann » Sun May 20, 2012 1:59 pm
The car is dríven very gently, he cops heaps of flack because he wont rev it past 5k, but he looks like the type and talks like the type.
Postby manga_blue » Sun May 20, 2012 2:01 pm
Nemo wrote:Are there any contact details for Athol Mullins? Can't seem to find him listed on the RTA list licensed certifiers.
http://www.rta.nsw.gov.au/registration/downloads/bulletin_1_v7_02_02_2012.pdf
FYI, just checking for engineers today for some other stuff and found that RMS has updated the list. It's now at http://www.rta.nsw.gov.au/registration/downloads/bulletin_1_v21_17_05_2012.pdf
CHRISTolo
Postby CHRISTolo » Wed Jun 06, 2012 1:37 pm
Updating the links.
VSCCS brochure - http://www.rta.nsw.gov.au/registration/ ... _final.pdf
Licensed certifiers - http://www.rta.nsw.gov.au/registration/ ... vsccs.html
Anyone recently got engineered a turbo NA6 under this new scheme?
zossy1
Postby zossy1 » Tue Jun 19, 2012 4:52 pm
Just had my NA8 engineered under the new scheme.
Mods:
Turbo;
FMIC;
Boxed pod air filter;
Megasquirt ECU;
Exhaust;
NB8B brakes;
Coilover suspension.
The process is very similar to what it used to be, except a blue slip is no longer necessary. You get your IM240 and weighbridge ticket, and then take it all to your engineer with a list of your mods. He/she goes through the car, checks off the weighbridge and IM240, and gives you a document entitled "Compliance Certificate". This document is an official report listing all your mods and your car's details before and after the mods. It is signed by the engineer, and is entered by the engineer into the RTA database. So you drive the car away from the engineer and it is legal - you keep a copy of the certificate in the car at all times.
The next time you register the car, your rego papers list the fact that the car is engineered as modified "in accordance with Compliance Certificate XXXXXXX (number)". You keep the certificate in the car at all times to show to Mr Plod should he be interested in the nature of your hot little beast, and also for your rego inspector when they do your next pink slip.
Expect to pay between $700-$1500 for your Compliance Certificate (depending on the engineer and the extent of the mods). The IM240 is free but is a long wait so book early. Weighbridge tickets can be free or anywhere up to $50 depending on where you go. BEFORE YOU GO TO THE WEIGHBRIDGE, LIGHTEN THE CAR AS MUCH AS POSSIBLE! Extra weight will be charged to you on your rego so keep it light - low fuel load, no spare wheel, etc etc.
In short, there is little excuse not to get your car engineered. The tuning to get you through IM240 will probably be more expensive than the rest of the process, unless you DIY the tuning or get it tuned for E85 (recommended).
Just read above comments on Athol Mullin. Athol was going to engineer my car but has been uncontactable for the last couple of months. I used a guy in Narellan (listed on Bulletin no.1). Shop around, you can negotiate prices.
A.Chen89
Postby A.Chen89 » Tue Jun 19, 2012 9:25 pm
Cheers zossy for the information, very helpful! Strongly considering a turbo conversion (engineered) now.
Hjt
Postby Hjt » Tue Jun 19, 2012 10:50 pm
I'm looking to get seats and roll bar engineered. They would obviously meet the compliant ADRs, would the engineering costs be very high?
Postby NitroDann » Tue Jun 19, 2012 10:55 pm
Still 3-400.
Suspense
Postby Suspense » Tue Jun 19, 2012 11:12 pm
Hjt wrote:I'm looking to get seats and roll bar engineered. They would obviously meet the compliant ADRs, would the engineering costs be very high?
There's been a few people talking about engineering small scale items lately in the Sydney area. Maybe if we had a few of us together we could get a bit of a discount? Assuming it would be cheaper/easier for the engineer to be looking at the same parts of the same model car.
Hjt
Postby Hjt » Tue Jun 19, 2012 11:38 pm
sadly for $400, it's worth running a defect atm. Sadly it's the system
