MX-5 Wheel Alignment Specs..
Technical Guidance for doing those Tricky Jobs
apsilon
Re: MX-5 Wheel Alignment Specs..
Postby apsilon » Tue Mar 06, 2018 9:29 am
Going to get my new NA aligned as I suspect it's on pretty standard (read poor) alignment given the "comfort" tyres it's currently wearing so thought I 'd search and refresh my memory on specs and it appears that may have been a good idea.
Back when I had my '94 consensus was about 1/2 degree more negative camber in the rear than the front. In the time I've been away this seems to have flipped and now be 1/2 degree more negative in the front than the rear. is that correct?
Toe is now recommended to be neutral rather than about 1 - 2mm toe in and caster remains as much as possible.
All sound about right? Only looking for a spirited street alignment for stock suspension set up at this stage.
'97 Neo Green limited edition
Postby 93_Clubman » Thu Mar 08, 2018 11:43 am
There used to be a couple of other wheel alignment threads on here that would allow you to track changes over time, but looks like they're gone - did find these though:
2016: viewtopic.php?f=30&t=72118
2006: viewtopic.php?f=30&t=17451
2006: viewtopic.php?f=30&t=17832
apsilon
Postby apsilon » Thu Mar 08, 2018 12:41 pm
I've picked some basic alignment specs that'll suit at this stage. Goal right now is to ensure it is actually aligned and look for any potential issues. Once I know it's OK I can develop the alignment over time.
shirtz
Postby shirtz » Fri Nov 16, 2018 1:34 pm
just had my first alignment after putting the MCA's in. was extremely wack before but current settings are
-2.5 camber front and back, zero toe at the front and 1mm toe at the back.
went for a spirited drive and went well apart from the little bit of scrubbing, but that's my fault I guess :)
apsilon
Postby apsilon » Mon Dec 10, 2018 9:25 am
Thought I'd add to this thread rather than create a new one as I have what I think is a simple question regarding caster. I know what it is and what effect it has etc but what I'm wondering is, how is it adjusted on NA/NBs? Looking at alignment specs recommended on this and the big forum as well as vendor sites I often see a specific amount recommended (usually around 4.5 - 5deg) or the simple "max positive you can get" but having recently pulled all of the suspension apart on my car, I don't see how caster actually adjusts on them. So am I missing something or is there no point in specifying caster when having an alignment done?
RS2000
Postby RS2000 » Mon Dec 10, 2018 11:56 am
If you study the location of the lower control arm inner pivot points, they are not equi-distant forward & rearward of the hub/axle centre line. Actually the front inner pivot point is close to the hub centreline & the rear pivot point is well towards the rear.
Therefore, moving the front pivot inwards & the rear pivot outwards, moves the wheel hub forward to increase caster. But it's all a compromise, you can't have max caster & max camber at the same time.
lucmor444
Postby lucmor444 » Fri Dec 28, 2018 6:51 am
apsilon wrote:I've picked some basic alignment specs that'll suit at this stage. Goal right now is to ensure it is actually aligned and look for any potential issues. Once I know it's OK I can develop the alignment over time.
So what specs did you end up with (I need to get my own done soon)?
apsilon
Postby apsilon » Fri Dec 28, 2018 3:51 pm
Nothing revolutionary. I asked for:
Front:
4.5deg of caster
-2deg camber
0 toe
Rear:
Half a degree less than front (so if front reached the requested -2 then rear -1.5)
1.5mm of total toe in (0.75mm each side)
Wasn't able to get more than -1deg of camber in front for some reason. Everything else was spot on what I asked for. I'll look into it more in the new year, try a more reputable alignment place to make sure it wasn't the operator and/or calibration of the equipment as it looks to my eye to be a lot more than -1deg and if necessary order some extended lower ball joints in order to get more.
StuwieP
Postby StuwieP » Sun Dec 30, 2018 10:29 pm
I couldn't get more than -1 deg on my NA while it was at stock height. I think that's normal.
My NA6/SE build
Engine #1 RIP 04/07/2020
lucmor444
Postby lucmor444 » Sun Dec 30, 2018 10:48 pm
apsilon wrote:Nothing revolutionary. I asked for:
Front:
4.5deg of caster
-2deg camber
0 toe
Rear:
Thx
apsilon
Postby apsilon » Mon Dec 31, 2018 6:29 am
StuwieP wrote:I couldn't get more than -1 deg on my NA while it was at stock height. I think that's normal.
I got slightly more on the first alignment I did around mid year at stock height. It's now slightly lowered and could get less. Everything else is spot on and I'm not concerned about the car being out from an accident. I just think it's the alignment place I used.
ManiacLachy
Engaged
Postby ManiacLachy » Mon Dec 31, 2018 8:32 am
You will probably need to pick up some extended lower ball joints. The lowest I can get now is -2*, but prior I could only get about -1.8* on my SE.
apsilon
Postby apsilon » Mon Dec 31, 2018 9:45 am
Already on the list. I was going to buy them before but held off as I knew camber should increase when lowering the car and it's not going to be a track only car so I don't need extreme. I'll order some and they can go in when I do the steering rack.
Nikki
Postby Nikki » Tue Feb 12, 2019 8:26 pm
Front:
4.5deg of caster
-2deg camber
0 toe
Rear:
Hi, looking to get an alignment done for the first time on my first car.
Just wondering why u got 1.5mm toe in the rear when all the other posts recently seem to recommend 0 toe. What is the benefit/disadvantage?
apsilon
Postby apsilon » Wed Feb 13, 2019 6:04 am
Mostly because I'm out of practice having dríven 4WDs a lot in the past decade. Toe in, in theory at least, will have slightly less tendency towards oversteer so should be a little safer. Alignment is also set when the car is standing still. In theory when the car is moving forward there's likely enough play in the suspension that drag will pull the tyres back out reducing toe in towards neutral toe. If you're already at neutral it could become toe out.
All theory and guess work and I'm far from an expert so don't take my actions as highly informed but I figured it couldn't hurt to have a small amount there.
