FAQ: Clubman
Technical Guidance for doing those Tricky Jobs
malibu Q
Re: FAQ: Clubman
Postby malibu Q » Mon Jan 26, 2015 11:02 pm
I've done more reading on this and Miatanet agrees with 93Clubman. It states (here) that both the NA6CE and the R Package have 12mm rear bars. I think it's more likely that the talk on CR is incorrect.
Re: FAQ: Clubman
Postby 93_Clubman » Mon Mar 30, 2015 4:29 pm
Links to pics on page one of this FAQ no longer work since forum issue on 31 Dec 2014: viewtopic.php?f=52&t=66604
Original pics reattached plus some additional:
1993 Mazda MX-5 Clubman (taken Nov 93) ABU-04C was subject of Wheels Magazine article of Jan 94.jpg
Clubman Vehicle Information sticker drivers side B pillar-door jam-used 1992-2002 by Mazda Aust dealers when ordering parts-no rwc implications.JPG
Re: FAQ: Clubman
Postby 93_Clubman » Mon Mar 30, 2015 5:45 pm
Re: FAQ: Clubman
Postby 93_Clubman » Mon Mar 30, 2015 5:48 pm
Re: FAQ: Clubman
Postby 93_Clubman » Tue Mar 31, 2015 11:11 am
Pic from page two reattached:
Note following are USDM Miata NA colours:
Szemen wrote:
MAZDA MX-5 MIATA PAINT COLORS
This info comes from a site called PaintScratch.com, sellers of touch-up kits and paint packages that match original factory colors. All that's been done is compiled the paint codes for each year - it's up to you to check your car and see what matches.
You can find your color by simply opening up your driver door and, on the info sticker on the door jamb, looking for a two- or three-digit paint code.
There are some other special colors listed (late additions, limited-production, etc.) that I don't yet have codes for, or that I'm unsure of the code number for. They're listed "as-is" for the time being.
1990 MAZDA MIATA
3L - Silver Stone Metallic Clearcoat (also coded as 4G; late-year addition)
DU - Mariner Blue
SU - Classic Red
UC - Crystal White
1991 MAZDA MIATA
3L - Silver Stone Metallic Clearcoat (also coded as 4G)
DU - Mariner Blue
HU - British Racing Green (Special Edition only)
SU - Classic Red
UC - Crystal White
1992 MAZDA MIATA
6W - Perky Blue Metallic Clearcoat
DU - Mariner Blue
HZ - Sunburst Yellow (extra-cost; only 1519 HZ cars built)
PX - Brilliant Black
PZ - Brilliant Black Clearcoat
SU - Classic Red
UC - Crystal White
1993 MAZDA MIATA
DU - Mariner Blue
SU - Classic Red
UC - Crystal White
1994 MAZDA MIATA - note that this year's R-package Miatas may carry white or blue racing stripes
M8 - Montego Blue Mica Clearcoat (also coded as 2A; only on the 3000 M-Edition models built)
PT - Chaste White
SU - Classic Red
-- - Laguna Blue Metallic Clearcoat (only 1797 such cars built)
1995 MAZDA MIATA
M8 - Montego Blue Mica Clearcoat (also coded as 2A)
PT - Chaste White
SU - Classic Red
-- - Laguna Blue Metallic Clearcoat (only 562 such cars built)
-- - Merlot Mica Clearcoat (only on the 3500 M-Edition models built)
1996 MAZDA MIATA
PT - Chaste White
SU - Classic Red
-- - Starlight Mica Clearcoat (only on the 2968 M-Edition models built)
1997 MAZDA MIATA
12K - Twilight Blue Mica Clearcoat (only on the 1500 STO models built)
PT - Chaste White
SU - Classic Red
-- - Marina Green Mica Clearcoat (only on the 3000 M-Edition models built)
wade
Re: FAQ: Clubman
Postby wade » Tue Mar 31, 2015 2:54 pm
Well that explains why my car has a black roof
Re: FAQ: Clubman
Postby 93_Clubman » Mon May 25, 2015 1:21 pm
Mazda Australia webpage screenshot mentioning Clubman & some specs:
Eeyore
Re: FAQ: Clubman
Postby Eeyore » Sun Jun 14, 2015 10:45 am
Are there any aftermarket springs that match the factory Bilstein shocks?
Kurt
1971 1300 Estate Deluxe
1973 1300 Wagon
1979 RX7
Re: FAQ: Clubman
Postby 93_Clubman » Sun Jun 14, 2015 12:42 pm
In the past most forumites have used Eibach or King springs on the Clubman Bilsteins. From old posts Eibach springs seemed to be preferred on Clubman Bilsteins, but some also preferred King springs. But Espilier springs (from MX5Plus) have also been used, most notably by tbro to great effect:
viewtopic.php?f=30&t=30330
There may also be other springs available these days.
Eeyore
Re: FAQ: Clubman
Postby Eeyore » Tue Jun 16, 2015 7:59 pm
Maybe the Eibach Mazdaspeed springs would be suitable. We are looking to lower the Clubman and one of my local mechanics insisted that Bilsteins are usually quite sensitive incorrect spring rates and that putting any old lowered spring in the car would ruin the ride.
Kurt
1973 1300 Wagon
1979 RX7
Re: FAQ: Clubman
Postby 93_Clubman » Wed Jun 17, 2015 12:23 pm
A former Pres of NSW MX5 Club spoke with the Bilstein importers about the mismatch between the Clubman shock & spring rates, & was advised Mazda reverted to the stock NA6/NA8 spring at the last moment without telling Bilstein. Result was the very firm ride & bounciness over uneven surfaces as the Bilstiens didn't have enough rebound damping. It would be interesting to know what spring Mazda originally planned to use as they may better suit the Clubman Bilstein.
Heasmans in Sydney or Quadrant Suspensions in Melbourne might know, & certainly revalve & rebuild Clubman Bilsteins with very good results.
Indeed, jonosx on this forum works for, or used to work for, Heasmans: <jonathon.mckinnon@bilstein.com.au>
memberlist.php?mode=viewprofile&u=7587
Btw, correction to my previous spelling of the springs tbro used on his Clubman Bilsteins - they were: Espelir
Re: FAQ: Clubman
Postby hks_kansei » Wed Jun 17, 2015 1:41 pm
Eeyore wrote:Maybe the Eibach Mazdaspeed springs would be suitable.
Bear in mind that Eibach springs, and the Eibach/Mazdaspeed springs weren't the same specs.
My GF's car had regular Eibach springs in it, and a friend's car has the Mazdaspeed Eibachs in it.
Apart from the visual difference (Eibach = black, Mazdaspeed = grey) there was a difference in spring rates (well, by feel anyway)
The regular Eibach springs felt a little firmer to me than the Mazdaspeed ones, but it's hard to say 100% since the cars were each using different shocks.
When I get home i'll try and dig out the old jap magazine I have that lists the rates, pretty sure it lists both the Eibach and Mazdaspeed versions.
If not, I've got a copy of the old Mazdaspeed catalogue, which should list the Mazdaspeed spring specs.
Re: FAQ: Clubman
Postby 93_Clubman » Sun Sep 13, 2015 3:58 pm
MX5 ADM OEM anti-roll bar sizes:
NA6: 19mm Front & 12mm Rear (except on the 1993 NA6 LE which were 19 & 11mm)
NA8: 19mm F & 11mm R (USDM standard Packages: 19mm F & 11mm R)
NA8 Clubman w TorSen: 20mm F & 11mm R (USDM R Package w TorSen: 20mm F & 12mm R)
NB8A: 22mm F & 11mm R
NB8A 10AE w TorSen: 21mm F & 12mm R
NB8B: 22mm F & 12mm R
SP: 22mm F & 12mm R
SE w Torsen: 23mm F & 14mm R
NC1: 21mm F & 12mm R
NC2: 23.5mm F & 11.5mm R
chrons_rotary
Re: FAQ: Clubman
Postby chrons_rotary » Mon Sep 14, 2015 11:20 pm
Does anyone know the VIN range for Clubman models? I.e. are they all random or group together for each year?
I was sold a Clubman, but it didnt have any Bilstein sticker or a door jam sticker, and no Bilsteins.
It did have a T1 TorSen, manual steering, no air con/power steering and a Clubman sticker on the boot lid.
Ken.
myredmx5
Re: FAQ: Clubman
Postby myredmx5 » Tue Sep 15, 2015 9:11 am
I emailed Mazda all my cars details and they were able to confirm I had a Clubman and even some history.
I think the stickers were something individual dealers did or didn't do.
