Brake Pad change for Dummies (with pics)
Technical Guidance for doing those Tricky Jobs
Tony
Re: Brake Pad change for Dummies (with pics)
Postby Tony » Fri Dec 09, 2011 6:11 pm
You should also take the opportunity to clean and re-lube the slider pins.
'09 NC2
RX-747
Postby RX-747 » Fri Dec 23, 2011 12:11 am
Good write up, just a note with the bedding in procedure... It is important that when doing the hard braking/ bedding in not to engage ABS (if your model has it), or come to a complete stop/ lock the brakes when braking hard because you risk glazing the pads straight away and they will start squealing early, that's just my 2 cents...
