VIDEO GUIDE - Fixing Heater Return O-Ring Coolant Leak
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
Boosted Autos
Postby Boosted Autos » Mon Jun 12, 2017 12:52 am
I've put together a detailed How-To video showing how to fix the very common coolant leak from the o-ring that seals the water pump to the heater return hard line.
The video also shows how to remove the exhaust manifold heat shield and burp the cooling system.
Hopefull some of you find this useful
Return to “MX5 Technical Guides”
