Oil Filter - impossible to get at to replace
Technical Guidance for doing those Tricky Jobs
Moderators: timk, Stu, -alex, miata, zombie, Andrew, PUR157
Re: Oil Filter - impossible to get at to replace
Postby NitroDann » Sat Jan 18, 2014 10:44 am
Filter relocation kits are available, the Works Engineering one is popular, I have installed a few, they are great quality.
There has been a few threads on this, basically the answer is don't do up oil filters tight, they don't need to be tight. Just on with your finger tips and an eighth of a turn after its 'on'.
This will turn into a 50 page long thread of people who do them up too tight whining, so don't tighten it so much.
chrisearl88
Postby chrisearl88 » Sat Jan 18, 2014 11:17 am
Steering full lock the the right, take off front right wheel and attack it from there. Dont be afraid to lie on the ground, oh and wear long sleeves.
Just think, if Nigella Lawson asked you to open her jar of mustard, you man up and you get that jar open!
MrRevhead
Postby MrRevhead » Sat Jan 18, 2014 12:47 pm
hejira
Postby hejira » Sat Jan 18, 2014 12:50 pm
If your hand/arm is too big then how do manage to fit in an mx5 to drive it? or are you not the owner?
Postby manga_blue » Sat Jan 18, 2014 1:23 pm
My father bought one of these cloth strap wrenches about 40 years ago. It's still going. I have used it once on every car we've owned. After that first time it's fingertips only - never had a leaking filter.
Postby Lokiel » Sat Jan 18, 2014 4:06 pm
Oil filter relocation kits can be a bitch to fit but once fitted, you'll love (or at least appreciate) them every time you have to do a filter change.
I'd recommend that you fit it yourself too so that you can locate it where it's most convenient for you to change the filter rather than some turn-key garage who only cares about fitting the kit in the fastest time possible. The other option is to look at what others have done and tell the garage that's how you want it installed.
Hjt
Postby Hjt » Sun Jan 19, 2014 11:00 pm
the filter is simple to change, the hard parts keeping it all clean.
sailaholic
Postby sailaholic » Mon Jan 20, 2014 1:55 pm
Take the bottom tray off?
I hope you mean inlet manifold and not exhaust manifold like you stated.
Return to “MX5 Technical Guides”
