SDT Track Day - Morgan Park 24 October
Queensland Motorsport
Moderators: timk, miata, Andrew, AJ, JBT
MattR
Re: SDT Track Day - Morgan Park 24 October
Postby MattR » Fri Oct 23, 2015 1:02 pm
You will go through at least half a tank.
Fill up before heading out and you will need to fill up coming home :)
You will get plenty of track time.
And take advantage of the tuition offered. When you start running the whole track, grab one of the guys to go with you, you will learn a lot.
This is one of the few opportunities you will get to have basically free driving coaching provided to you with instant feed back.
MXO005
Postby MXO005 » Fri Oct 23, 2015 1:24 pm
Thanks again all.
Re the rollbar.
It's been a big struggle to get the front four bolts lined up.
Now the feet sit with the rear most two holes on each foot a fair way off the parcel shelf. Should just about be enough to get the nuts threaded on the bolts.
Do we just 'crunch' the parcel shelf to meet the rollbar?
Most things online I've read say there will be a gap.
Wish I could work out how to quickly post pictures but I'm just wasting time. :evil:
Ian
Silver '94 Eunos Roadster - Nothing much to report.... yet!
Steampunk
Postby Steampunk » Fri Oct 23, 2015 3:01 pm
Keep tightening the bolts until they are "properly" tight without using what you feel like excessive force. If you think that you're deforming the bodywork too much then leave it at that. We can easily tighten them up tomorrow.
Those roll bars were actually measured and fabricated off an NB and when they trialled it on an NA and only found marginal tolerance difference they left it at that. So fit on NA. Aren't as good.
Pretty sure my old NA was the first commercial roll bar fitted for NA, may have been the very first regardless.
Another tip: bring as many tools and spares as you can. I always bring all my tools, oil and coolant, zip ties, tape, assortment of nuts and bolts etc. I even bring parts that were working fine when i upgraded, eg spark plugs and leads, brake pads, radiator cap....
Postby Magpie » Fri Oct 23, 2015 3:09 pm
Don't forget I'll have the back of the Amarok to carry some stuff. I'll have a range of tools etc with me as well.
Steampunk
Postby Steampunk » Fri Oct 23, 2015 3:18 pm
Yes, we are well aware of that, but ... as nice as it is... you can't spoon feed us too much Mark.
Reserve that for some other members on this forum *SNAP* :wink:
19 hours and counting...
MXO005
Postby MXO005 » Fri Oct 23, 2015 3:29 pm
Cheers gents.
I think she's in.
Plenty more tightening and a bit more refitting of odds and sods to go. Think I'll sleep tonight.
If I wasn't a deformed hunchback before, then I definitely am now.
Will be making vroom vroom noises on the way home.
Sent from my SM-G900I using Tapatalk
Ian
MattR
Postby MattR » Fri Oct 23, 2015 4:05 pm
Steampunk wrote:Another tip: bring as many tools and spares as you can. I always bring all my tools, oil and coolant, zip ties, tape, assortment of nuts and bolts etc. I even bring parts that were working fine when i upgraded, eg spark plugs and leads, brake pads, radiator cap....
That's more gear than I take for my race car to a race meeting..... :lol: :lol: :lol: :lol:
For this day, if the car is in well maintained condition it will be fine.
The most important thing is adjust your tyre pressures before you get there, measure at cold before you leave home and note how much air is needed and put that much in at the servo.
And when you get there, clean everything out of the car and boot, you don't want anything rolling around the floor or anything flying around the interior.
Postby Magpie » Sat Oct 24, 2015 5:50 pm
What a day! Thanks SDT and all the MX5 drivers, enjoyed the day and the company! The track combination (J) that was used at the end was so much fun.
Chris gave some great feedback on the car and was about 0.5 sec quicker than my time, however he did suffer a weight advantage with me in the passenger see!
I'll make a separate post on the FZ201's vs the AD08's, suffice to say based on the current setup of the car it was faster with the AD08's on by 0.5 secs. I'm not surprised.
There was some great entertainment on the day, for example my mistake...
Steampunk
Postby Steampunk » Sat Oct 24, 2015 6:17 pm
WHAT A TRACK!!
When is the next one!?!?! :twisted:
Steampunk
Postby Steampunk » Sat Oct 24, 2015 6:30 pm
Hard-braking much? :twisted:
Rear wheel
Front wheel
Postby Magpie » Sat Oct 24, 2015 6:35 pm
Must thank Chris for taking Jaye out in the SDT for a few laps, he is still smiling.
Used 80 ltrs of E85 and it was SO MUCH FUN!
MXO005
Postby MXO005 » Sat Oct 24, 2015 6:57 pm
Fantastic day.
Cheers everyone.
Staying in Warwick for the rodeo.
Going to give the show rides a miss. Already done enough spinning today ;0)
Ian
gslender
Postby gslender » Sat Oct 24, 2015 7:02 pm
So disappointed I could not attend. Next time for sure!
Sent from my iPad using Tapatalk
Postby Magpie » Sun Oct 25, 2015 5:48 pm
Many thanks to Chris for again taking my car for a spin, despite the disadvantage of having my weight in the passengers seat and having no seat time in my car in just a few laps he was already quicker than my PB :)
Can't say enough about how much you can learn on these days not only about yourself as a driver but about your car.
Comments on the car were:
Excellent initial turn in, however then starts to push and rear brakes lock up too early.
As we discussed the alignment was not optimal for the FZ201's (only -2.5 camber), front spring rates could be increased and more than likely a manual brake bias (discussed the current setup and pads being used).
My line is Red Chris is Blue (Layout E). Obvious on T6 and T11
T1-T2
ImageT1-T2 by Eipeip, on Flickr
T3 (Under Bridge)
ImageT3 (Under Bridge) by Eipeip, on Flickr
T4-T5
ImageT4-T5 by Eipeip, on Flickr
T5-T6-T7
ImageT5-T6-T7 by Eipeip, on Flickr
T7-T8
ImageT7-T8 by Eipeip, on Flickr
T8-T9-T10-T11
ImageT8-T9-T10-T11 by Eipeip, on Flickr
This is from the new data logging software by RacePak (DataLink II)
Chris best lap.
ImageDataLink II by Eipeip, on Flickr
Compare mine to Chris
ImageDataLink II Compare by Eipeip, on Flickr
And here is the lap by Chris (the camera suction cap was a bit loose, adds to the sense of speed)
The American
Postby The American » Sun Oct 25, 2015 7:54 pm
Must have been great to have some clear air with no engine misfiring! Lecky ties!
Return to “Queensland”
