slyfox2151 wrote:Its a shame i was working that day...
I picked up and towed the white lancer that broke an axle out the front of lake side.
Thanks again for the tow ;)
Moderators: timk, miata, Andrew, AJ, JBT
Racing Logic wrote:slyfox2151 wrote:Its a shame i was working that day...
MXO005 wrote:I'm still trying to run the novice lines that Doug taught but couldn't keep Karousel a constant curve on Monday and pretty sure I never got close to that gutter curb on the exit all day. Normally push right out there. Turning in too early on the first apex?
MXO005 wrote:Thanks very much Rossand Mark
Hopefully I can get my full session 2 video up by the weekend and would really appreciate if you could find the time to have a look.
Thanks for the tip about the bridge. I really don't want to break free there.![]()
Had been wondering about trying to shave some out of that corner. At the moment I'm staying fully left until the point where the bus stop gets closest to the track [Small stain on the track that Doug used to point out on the walk around from a previous fire] and apexing where there's the little extra tarmac outside the white lines.
...The run out of the Karousel is up hill to a blind crest and you need to stay left edge all the way up,
pulling fourth gear at the top or just over the crest, then continuing to hold the left edge until you
get to a point where the Bus Stop nearly rejoins the track and the grass is less than a metre between
the two surfaces. Note, from this point the bus stop goes away and returns to rejoin the main track at
a later point. The bus stop is a departure from the main track only used by bikes at Lakeside Park to
reduce speeds under the bridge and accidents resulting, please refer to the track map.
From this point the apex for Turn 3 is around 20 metres before the bridge and, if you’re on the
pace, you grab fifth gear around this point. From that apex and under the bridge, you aim for the left
edge at the second of the two blind crests at Lakeside Park and then aim for the 40cm track light on
the Armco barrier on the right hand side of the track before Hungry corner....
MXO005 wrote:Hoolio, that's a great debut.
I know you were asking about a track car before. All I can see from the entrants list is that it is red.
We all know red cars go faster but I think it's time to spill the beans on the other details
Steampunk wrote:Good to see hoolio enter the fray and his car survived the day...albeit sounding like a Sopwith Camel sans wings
And I was slightly concerned that VAT seemed to be quite knowledgeable about kidnappings, assassination, drug running/money laundering involving famous car designers, at the same time showing up with new suspension bits and new AD08R tyres... hmmmm....![]()
Steampunk wrote:Those instructions are a little confusing and long winded, plus mentioning "....grab 5th gear...." should be totally ignored because I certainly don't come close to wanting to change up to 5th in either my current NA6 or previous NA8.
