MX5 CLUB OF QLD QR TRACK DAY 26 MAY 2014
Queensland Motorsport
Moderators: timk, Andrew, miata, AJ, JBT
Re: MX5 CLUB OF QLD QR TRACK DAY 26 MAY 2014
Postby Magpie » Fri May 23, 2014 6:48 pm
Hopefully I can make it, partner dependant!
Picked up the car from Automotive Plus, it feels completely different, revs clean, crisp and an awesome sound, plus more torque across the rev range. Could not 'unleash' it on the way home, however Jap Nats should see what the new tune is like as well as the improved lower down torque.
Also have a new alignment.
zero00
Postby zero00 » Fri May 23, 2014 9:30 pm
Magpie wrote:Hopefully I can make it, partner dependant!
I'm polishing my nuts - less wind resistance I'm told - wheel nuts that is!
Give mine a clean over the weekend, maybe ven a polish seeing it's tipped to be around 27-28c and forecast Monday is around 27 and fine :wink:
Roger D-SUNSHINE COAST
CAR53
Postby CAR53 » Fri May 23, 2014 11:41 pm
This is hopefully the last track day normally aspirated. Automotive plus build of the new engine is progressing so I'm hoping to run in with the SC next time.
It would be good to get into the 63s on the clubman with the hairdressers car without the hair dryer.
JOHN TOOMER
NC 2.5L HKS GT7040 Supercharger
LAKESIDE 1:01 QR CLUBMAN 1:01.69
JBT
Postby JBT » Sat May 24, 2014 7:22 am
Notice
We have been given advice that we may get on to the track 30 minutes early.
It's up to all the participants to be ready for this to happen so, be at Willowbank early (say 10:00am ish) and have all your paperwork completed - this includes a printed copy of your CTP extension - to take advantage of this offer. :D
zero00
Postby zero00 » Sat May 24, 2014 10:59 am
Thanks JBT - will do!!
Postby Magpie » Sat May 24, 2014 4:03 pm
I went under 1:08 today at Jap Nats, very happy with the car!
Will use Monday (if there) as a test day as I need to test some settings.
speed freak
Postby speed freak » Sat May 24, 2014 7:49 pm
Forms are printed and filled in. Changing the oil in the car tomorrow and doing a quick check over to make sure everything is in good health, then off to the atm to get the payment out as Ill be paying on the day now. Then get all other bits n pieces out ready for Monday morning :)
zero00
Postby zero00 » Sat May 24, 2014 9:33 pm
speed freak wrote:Forms are printed and filled in. Changing the oil in the car tomorrow and doing a quick check over to make sure everything is in good health, then off to the atm to get the payment out as Ill be paying on the day now. Then get all other bits n pieces out ready for Monday morning :)
Car washed, tyres checked & blackened, valve caps polished, de-crapped inside so I'm ready! :roll:
timk
Postby timk » Sat May 24, 2014 10:11 pm
Car is ready to go; changed over my wheels and brakes, then kicked the tyres a few times. Anyone want to help me do up my harness with the HANS on? :lol:
Trackphotos
Postby Trackphotos » Sat May 24, 2014 10:26 pm
zero00 wrote:de-crapped inside so I'm ready! :roll:
Doesn't that normally come after the first cup of coffee for the day?
ljs18
Postby ljs18 » Sun May 25, 2014 11:43 am
JBT wrote:Notice
Ouch. What time is the drivers briefing? Have to work that morning and will be leaving the airport 10.30 latest. Should be there 11.30. Will I still make it?
timk
Postby timk » Sun May 25, 2014 12:06 pm
ljs18 wrote:Ouch. What time is the drivers briefing? Have to work that morning and will be leaving the airport 10.30 latest. Should be there 11.30. Will I still make it?
If you have no other options to get out of work earlier then they are usually accommodating; I've had to turn up half way through a session and it was OK apart from forfeiting a bit of track time. If it is your first track day and you haven't been to a briefing before then it's probably a different story though!
zero00
Postby zero00 » Sun May 25, 2014 3:22 pm
I'm sure Brian and JBT will understand - I will mention that in the morning that you have to work
Thanks Sonke :wink:
speed freak
Postby speed freak » Sun May 25, 2014 5:12 pm
All ready to go, car is prepped and cleaned. All the gear is out ready to put in the car tomorrow morning. Only thing to do is the tyre pressures in the morning when I set off :D
Postby Magpie » Sun May 25, 2014 5:28 pm
Speed Freak what time will you be there?
Return to “Queensland”
Users browsing this forum: No registered users and 58 guests
