OMG, it's "The Phantom" unmasked:
Driver Training at Morgan Park Warwick QLD
Moderators: timk, Andrew, miata, AJ, JBT
Re: Driver Training at Morgan Park Warwick QLD
- MINX
- MINX
Managed to export this map from Harrys
Not sure but i think it was a 1.16 lap.
Speeds dont look as fast i thought and felt
If you zoom in you can see the speeds at corners, and the thickness of the green line indicates G force
- corners
- Vehicle: ND - Supercharged
Nice!
How did you find the new circuit?
- adidistyle
Your map is interesting Stu. It shows pretty much neutral through Turn 7 (T junction). Doesn't seem right.
I am guessing that green to the inside of the track is acceleration, and to the outside is Braking or lateral forces?
Adam Shipway
NA6 for track. NA8B SE (in slow progress)
Remember I'm onlly a poor NA 1.6 but here is a video. I used 2 cameras (Contour plus in the cab and a Replay XD on the lip). I will use the GPS data soon and the dashware.
- mazlot
Just because every-one else has, and I want to see if I can get this new-fangled technology to work.
http://www.youtube.com/watch?v=QlD7I13s ... ata_player
Farken Gruven
- MINX
Thats nice and smooth Jeff
I embedded it for you
The gear ratios and rev range are quite diferant to my SE, I never used 2nd at all, it must be much shorter.
- mazlot
Thanks for that, must find out how to do that
Second or third, much of a muchness, gives me something to do with my left hand
BTW, I lied, checked my dyno sheet, 86.5 killer wasps.
Farken Gruven
- MINX
They must be Big Imperial KW, I have more, but they are only small Metric ones
Users browsing this forum: No registered users and 30 guests
