Fire extinguisher A$15 at Aldi tomorrow
Moderators: timk, miata, Andrew, AJ, JBT
Time to replace the old one for me. Has passed all cams scrutineering.
- de Bounce
Re: Fire extinguisher A$15 at Aldi tomorrow
Check the Manufacture date before leaving the store
Some of them are old stock
- greenMachine
de Bounce wrote:Check the Manufacture date before leaving the store
... and the shape. There are a couple (few?) different shapes, make sure you either get a new (proper - not plastic) mount, or one that will fit your existing mount.
/psa
Just bought one.I opened about 10 random boxes in the pile,all the dates I checked were 10/15 or 11/15.mounts are folded flat steel, different than my 2014 but extinguisher looked identical.when fitted to my old mount fit was slightly loose(1-2mm) until I adjusted(bent) the clip slightly.
Mick
Mick
Thank you for the heads up
All the ones at my store were 10/15.... good enough for me
