Driver Training at Morgan Park Warwick QLD
Queensland Motorsport
Moderators: timk, miata, Andrew, AJ, JBT
Re: Driver Training at Morgan Park Warwick QLD
Postby Lokiel » Sun Aug 05, 2012 9:44 pm
OMG, it's "The Phantom" unmasked:
MINX
Postby MINX » Sun Aug 05, 2012 10:38 pm
MINX
Postby MINX » Mon Aug 06, 2012 10:21 am
Managed to export this map from Harrys
Not sure but i think it was a 1.16 lap.
Speeds dont look as fast i thought :( and felt :P
If you zoom in you can see the speeds at corners, and the thickness of the green line indicates G force
corners
Vehicle: ND - Supercharged
Postby corners » Mon Aug 06, 2012 11:08 am
Nice!
How did you find the new circuit?
adidistyle
Postby adidistyle » Mon Aug 06, 2012 1:36 pm
Your map is interesting Stu. It shows pretty much neutral through Turn 7 (T junction). Doesn't seem right.
I am guessing that green to the inside of the track is acceleration, and to the outside is Braking or lateral forces?
Adam Shipway
NA6 for track. NA8B SE (in slow progress)
Postby Magpie » Mon Aug 06, 2012 3:14 pm
Remember I'm onlly a poor NA 1.6 but here is a video. I used 2 cameras (Contour plus in the cab and a Replay XD on the lip). I will use the GPS data soon and the dashware.
mazlot
Postby mazlot » Mon Aug 06, 2012 4:18 pm
Just because every-one else has, and I want to see if I can get this new-fangled technology to work.
http://www.youtube.com/watch?v=QlD7I13s ... ata_player
Farken Gruven
MINX
Postby MINX » Mon Aug 06, 2012 4:31 pm
Thats nice and smooth Jeff
I embedded it for you
The gear ratios and rev range are quite diferant to my SE, I never used 2nd at all, it must be much shorter.
mazlot
Postby mazlot » Mon Aug 06, 2012 5:02 pm
Thanks for that, must find out how to do that :D
Second or third, much of a muchness, gives me something to do with my left hand :lol:
BTW, I lied, checked my dyno sheet, 86.5 killer wasps.
Farken Gruven
MINX
Postby MINX » Mon Aug 06, 2012 5:21 pm
They must be Big Imperial KW, I have more, but they are only small Metric ones
Return to “Queensland”
Users browsing this forum: Google [Bot] and 4 guests
