Racechrono Track Map - Eastern Creek South Circuit
New South Wales and Canberra Motorsport
Tony
Postby Tony » Fri Apr 10, 2015 7:41 pm
I'd be ever so grateful if someone could email me a Racechrono track map (.bin file) for the Eastern Creek South Circuit.
I've tried to set one up on a number of occasions and have comprehensively failed each time.
tony.king@live.com.au
Many thanks in anticipation...
'09 NC2
Trackphotos
Re: Racechrono Track Map - Eastern Creek South Circuit
Postby Trackphotos » Fri Apr 10, 2015 9:05 pm
There is actually an smp South layout in the track library already. If you press the Tracks button, and press on the Library tab. It's listed as SMP South, and has 2 split markers. If you press the Copy button, it'll create a new file in the My Tracks section.
Tony
Postby Tony » Fri Apr 10, 2015 9:41 pm
You must have a different version to me as I can't see anything other than the original Eastern Creek Circuit and the go kart track. The version I'm using has tracks in .bin files.
If someone has a file and could email it to me I'd be very appreciative.
Thanks...
'09 NC2
Trackphotos
Postby Trackphotos » Fri Apr 10, 2015 9:45 pm
Just emailed it. Hopefully it's compatible with your version.
