It just so happened the quickest lap was using 3rd.
I struggle with inside wheel spin and i think it might have something to do with either too large a rear sway or lack of rear shock travel (i think this might be it due to adjusting height via shock base).
All slow corners i get inside wheel spin just as if i had a open diff.
Being a torsen i think the inside is lifting and then losing all drive.
Did you use 2nd or 3rd Bryan on the fish hook and Turn 10 in your Na6?
I had a weird issue after the 3rd run.
My exhaust was hanging down low when i pulled back in and somehow the last 2 hangers on the muffler had snapped off just before the Weld.
So after a quick run around and some nice help in the form of metal cable ties and some old speaker wire along with a dusty old coat hanger i got back out there.
I will have to get this all fixed but figuring out how it happened is beating me.
