13th WA Meet Up - 3pm Saturday 29th November 2009
Western Australian Events
Moderators: miata, zombie, Andrew
Waz man
Postby Waz man » Mon Nov 30, 2009 5:48 pm
Hey Pete
I like the lump of metal stuck in your engine bay.
Are you going to make the 20th?
We all missed you at the last event.
Warwick
Barb's Short 57.83 Long 70.45
Motorsport Manager of the MX5 Club of WA (11 years service)
marcusus
Postby marcusus » Mon Nov 30, 2009 10:07 pm
Oh damn. Missed it. Not that I could make it anyway, as I had to work Saturday.
tinsfci
Vehicle: NA - V8
Postby tinsfci » Tue Dec 01, 2009 2:53 am
Waz man wrote:Hey Pete
Warwick
Nice air heater isn't it!
Will I make the 20th? At this rate I doubt it! The charger install is coming along nicely, still a few fidly bits to sort out but nothing impossible. Making an intake that clears the clutch master cylinder reservoir is probably the biggest issue, might be easiest to use a remote reservoir to gain some space for an elbow off the throttle body. The other biggie is 5th injector control, can't decide between changing the megasquirt for an adaptronic, or running a second megasquirt as a piggyback just to run one injector.
Can't wait to get it out on the track and at DTEC, no more down shifting to first for the end turns.
P
Street='94 with FFS Coldside. Sold :(
Race='97 with AVO (soon to be Absurdflow) and GT2560 <--- sod that... LS1 conversion underway!
Waz man
Postby Waz man » Tue Dec 01, 2009 12:38 pm
A lot of the early turbo systems had a 5th injector and you had to try and make it work but it was too much of a pain.
Would you not upsize the 4 existing injectors and get the computer remapped to control them.
That's what I did on my old system and I'm pretty sure Ian & Les have done the same.
tinsfci
Vehicle: NA - V8
Postby tinsfci » Tue Dec 01, 2009 6:38 pm
The coldside supercharger can’t fit an intercooler, so the main purpose of the fifth injector under the supercharger is cooling the intake charge. Theoretically water is much better for cooling than fuel, but the 5th injector adding 10 or 15% of the overall fuel required seems to work well (FFS customers seem happy) and allows you to keep the stock injectors without maxing out the duty cycle. I will probably upgrade to supra injectors anyway, but the 5th injector or water injection must be used for the pulleys I am running, which should be good for ~11 psi boost.
Probably time for me to get off my bum and make a garage thread on the install process instead of making a mess in this thread.
Return to “Western Australia”
Users browsing this forum: No registered users and 20 guests
