EOI: GOR Run/ 4kg Burger Challenge. November 7th.
Victorian and Tasmanian Events
Moderators: Stu, miata, Andrew
Pamex
Postby Pamex » Fri Aug 28, 2009 1:49 pm
Howdy folks,
John brought to my attention that there exists a challenge in Victoria... the 4kg burger.
http://www.spec.com.au/index.asp?sp=2&id=10352
Some specs for the tyre kickers:
- 28 cm across
- 1.5kg meat pattie
- 20 rashes of bacon
- 8 eggs
- 9 slices of cheese
Proposed is a very early start GOR run. Haven't been down this far, however looking at the map and looking to do as much of the GOR as possible before the turn off, it looks like the best route will be GOR until Tyrendarra, up to Heywood and then follow the road up to Cavendish, where the Cavendish Cafe is for imminent death.
Bear in mind the last eating challenge was the pounder at McDonald's, which I only just made it through, and apparently looked green afterwards, let alone the next few days. This is just over 8.8 pounds. I need to do some training for this.
So who's up for the GOR run and burger challenge? I'm placing it a couple of months away when the weather is fine and I've increased my stomach capacity mightily. :mrgreen:
CheyneX5
Postby CheyneX5 » Fri Aug 28, 2009 1:56 pm
Im so in, ill ride in with you pam, then i can drive your car back! you will be too full
90' NA6 - Classic Red
stevesports
Postby stevesports » Fri Aug 28, 2009 2:13 pm
urgh, no thx to teh burger. However i'm down for the drive.
Postby bruce » Fri Aug 28, 2009 2:17 pm
CheyneX5 wrote:Im so in, ill ride in with you pam, then i can drive your car back! you will be too full
You'd better leave the roof down...
devolutio
Postby devolutio » Fri Aug 28, 2009 2:19 pm
there is a great burger place in lorne called 'the bottle of milk'... we did a day trip there just for the burgers a couple of months back. not quite 4kg but very tasty! maybe an alternative for those not attempting the challenge?
Postby hks_kansei » Fri Aug 28, 2009 2:34 pm
SO UP FOR THIS!
bensale
Postby bensale » Fri Aug 28, 2009 6:49 pm
Good god! Thats obscene! I guess I'm up for that! :)
www.othersideproductions.com
Postby fastfreddygassit » Fri Aug 28, 2009 7:55 pm
Pamex wrote:I'm placing it a couple of months away when the weather is fine and I've increased my stomach capacity mightily. :mrgreen:
Don't be so hard on yourself. You are there now girl!!! :mrgreen: :mrgreen:
as am I :shock:
I am up for this ever since I saw the article in the herald-sun.
The burger is $38 or so and you get your money back if you eat it in one sitting.
As if that would ever happen!!
green_comet
Car Detailing Guru
Postby green_comet » Sun Aug 30, 2009 4:16 pm
Im down for a run, but yeah that burger sounds like a killer. :shock:
Return to “Victoria/Tasmania”
