The Weekly Vic MX-5 Meet-up!
Victorian and Tasmanian Events
Moderators: Stu, miata, Andrew
wun911
Re: The Weekly Vic MX-5 Meet-up!
Postby wun911 » Mon Sep 02, 2013 1:10 am
Asians know how to use leverage (buy the longest breaker bar you can find like 2m, then buy a piece of pipe to make it longer)
I find jacking the car up putting the breaker bar onto the nut then lowering the car's weight to push down onto the breaker bar helps undo difficult bolts, works well enough for exhaust bolts lug nuts etc.
But if you can't use the weight of the car to turn the tool or use a trolley jack to help turn the tool ie the bolt is on the wrong axis (eg sub frame bolts). I usually have to cut off the bolts with the angle grinder drill it out and buy new nuts and bolts.
every ounce counts
Postby fastfreddygassit » Mon Sep 02, 2013 8:52 am
wun911 wrote:Asians know how to use leverage (buy the longest breaker bar you can find like 2m, then buy a piece of pipe to make it longer)
:NETPOINTZ: :NETPOINTZ:
:mrgreen:
Are you coming Thursday for kebabs?
wun911
Postby wun911 » Mon Sep 02, 2013 9:52 am
should be good I got lights!
every ounce counts
Pamex
Postby Pamex » Mon Sep 02, 2013 7:45 pm
Only Wun needs an angle grinder.
If he was manly he'd cut it off with a razor blade.
shuey
Postby shuey » Tue Sep 03, 2013 10:46 am
meanmx wrote:Don't worry shuey you are like Arnold next to Wun. I think my daughter could kick Wun's ass in an arm wrestle. No angle grinder needed unless you are Wun. Might help to give the bolts a spray with some release agent the night before just incase. I can't see you having an issue though.
okay, so I managed to get those 2 bolts off with relative ease. I guess it does help to have 2x body mass as compared to my Asian brother..haha!
however having trouble getting the exhaust off the hangers. I've gone through the threads from miata.net and they mentioned using WD40 or spraying dishwashing liquid to lubricate the hangers, and using a tweezer-nose plier (which I don't have) but I'm finding it a little tough to get some leverage to slip them out. Of the 3, I've only managed to slip one out (one closer to the muffler tip).. Anybody have any advice or would like to swing by to lend a hand? :wink:
wun911
Postby wun911 » Tue Sep 03, 2013 11:09 am
Yeah use soap and a screwdriver, oh yeah I forgot I used a G clamp it helped me to squeeze the rubber off the hanger....
See Asian people don't need brute strength and muscle...
every ounce counts
meanmx
Postby meanmx » Tue Sep 03, 2013 11:35 am
Wd40 works well and then just slip a screwdriver down the hole to lever it wider. It's just that little button bit on the end of the hanger that's the problem. Once that is in the hanger it should come out easy. Unfortunately persistance is the key.
2014 VW Mk7 Golf R
Pamex
Postby Pamex » Tue Sep 03, 2013 11:45 am
I used the cheat's method. Because I'm replacing everything with new in my build, I just sliced them off with a razor blade.
:mrgreen: :beer:
shuey
Postby shuey » Tue Sep 03, 2013 11:51 am
Haha.. ok, Pam. :lol:
I don't have any replacement rubber hangers thing so no cheat method for me..
Ok, I'll try again later tonight. Thought I'd score a win with the bolts till I got floored by the hangers. Currently sporting a sore back so probably hindering movement a bit.. /grumble
Pamex
Postby Pamex » Tue Sep 03, 2013 11:54 am
Seriously though, lots and lots of WD or soapy water should do the trick. They can be a pain.
(If you get really, really frustrated, you can get them new for about $4 each at most car shops. Or if you like breaking things for the sheer fun of it like I do! :P)
meanmx
Postby meanmx » Tue Sep 03, 2013 12:08 pm
shuey wrote:Haha.. ok, Pam. :lol:
You need to get under the car a bit more often. You're a bit soft :mrgreen:
2014 VW Mk7 Golf R
Postby KevGoat » Tue Sep 03, 2013 1:28 pm
shuey wrote:Currently sporting a sore back so probably hindering movement a bit.. /grumble
... my bad Scott ... you've been reading too much from me complaining about my back :mrgreen:
shuey
Postby shuey » Tue Sep 03, 2013 2:43 pm
Pamex: I am seriously contemplating your cheat method, UGPM..haha! :mrgreen:
Meanmx: That's not a nice way to tell a person he is fat..haha! but ok, I will try again
KevGoat: Well it's not as bad as your back, but still a little annoyance since I tweaked a muscle when I was hauling out trash for hard rubbish week.
meanmx
Postby meanmx » Tue Sep 03, 2013 3:01 pm
I'm in no position to call anyone fat. Maybe a better term is that you are a delicate flower :mrgreen:
2014 VW Mk7 Golf R
Postby hks_kansei » Tue Sep 03, 2013 3:08 pm
Shuey, if you've got a set of open ended spanners you can use them to help pry the rubbers off.
I braced one against the hanger, and the other I put the open end spanner bit onto the back of the rubber and levered the two spanners against each other.
Once the mushroomed head of the exhaust hanger has popped past the opening in the rubber it should be easier to slide it off.
I'd recommend dishwashing liquid as lube, it's thicker than WD40 so sticks a bit better.
you can also rinse it off easily.
Return to “Victoria/Tasmania”
