Victoria Dyno Day 21st of June ( 3 Places LEFT )
Moderators: Stu, Andrew, miata
lightyear, the flyer with all the details in at the top of this page
http://www.mx5vic.org.au/events_calendar.asp
you could give dave a call to see if there is a spot available, byt i'm thinking you might be out of luck. couldn't hurt to ask tho!
- Damo
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
- Matty
- meanmx
Fatty wrote:thanks heaps dave, that was fun.
i missed you matty, and phil, slept in a bit. still it was good to catch up with the other guys. the dyno results took me by surprise a little bit... seems some recent mods have actually worked a little TOO well
Spill the beans Fatty. That post a little too cryptic
Ben
2014 VW Mk7 Golf R
- Matty
Fatty wrote:just in relation to the new motorsport rules ben..... thats all.
i advanced the timing a bit recently, which has pushed me up to 120.8 rwkw
i'm gonna have to retard the timing down again, to get below the 120rwkw limit for my class.
the biggest improvment would have come from my new exhaust tho.
Mate, flatten off the power curve so you have (just under) 120kW for as wide a rev band as possible and you'll be laughing all the way to victory.
- meanmx
Very nice Fatty. Just a thought. The two dynos I have been on both vary wildly with their outputs, so how do they say for sure that you are over? Can you use a different dyno for a different result. Have to remember to get myself an exhaust
Ben
Ben
2014 VW Mk7 Golf R
yes ben, at first i thought maybe the dyno is a little optimistic. but then again as matty said, most of the other cars there were stockish nb's, they all seemed to be putting out results that seemed consistent with previous results and published data. the SP that was there also came out bang on what you would expect it to be.... so i'm thinking the dyno was pretty accurate.
Matty wrote:Mate, flatten off the power curve so you have (just under) 120kW for as wide a rev band as possible and you'll be laughing all the way to victory.
hmmm so 120rwkw from say 3500rm all the way thru to 7000rpm. yeah sounds good to me
not sure i have the technology to acheive that tho, matty. maybe i should splurge on an electronic boost controller eh!
Ooooops. Who said you can't have too much power?
... and that won't work because that's the dyno we'll use as our reference dyno for classifications.
meanmx wrote:Very nice Fatty. Just a thought. The two dynos I have been on both vary wildly with their outputs, so how do they say for sure that you are over? Can you use a different dyno for a different result.
Ben
- meanmx
manga_blue wrote:Ooooops. Who said you can't have too much power?meanmx wrote:Very nice Fatty. Just a thought. The two dynos I have been on both vary wildly with their outputs, so how do they say for sure that you are over? Can you use a different dyno for a different result.
Ben
Oh well that clears that up then. Time to get to work Fatty
Ben
2014 VW Mk7 Golf R
Users browsing this forum: No registered users and 46 guests
