The Hunter Chapter April Run finishes at a National Park on the Central Coast where you will be able to have a surf, walk beaches and headlands or coastal heathlands.
When: Sunday 18th April
Where: Meet at the Thornton BP Servo at the end of the F3 Freeway - park at the lower northern end car park.
Time: 10.00 am - come earlier if you want a pre run caffein hit.
BYO everything for a picnic lunch at the finish.
Helen will be leading the run as I will be at the NSW Hillclimb Championship heat at Bathurst.
Phil
Hunter April Run - Finishes At Central Coast
Moderators: -alex, miata, Andrew, Midori
- PhilM
Rosso Corsa Red NA V Special
