Brisbane - MX5 / Lotus Club Run Mt Tamborine - 19/3/06
Queensland Events
Moderators: timk, Andrew, miata, AJ
timk
Postby timk » Tue Mar 21, 2006 8:48 pm
It was cool seeing you constantly behind us Jules :mrgreen:
jules
Guitar Hero
Postby jules » Wed Mar 22, 2006 9:50 am
I must admit I started coughing after a while, what with all the \"stuff\" that was blowing out of Geoff's car :shock: :shock: :shock:
Jules
sabretooth
Postby sabretooth » Wed Mar 22, 2006 10:05 am
Goddamn. Oil, or fuel?
I believe the valve stem seals may be going. Was it after cruising and then getting on the throttle that it happened? Pulling the head to do the valve stem seals would be much easier than worn piston rings!
It is a 16yr old motor, I guess I can forgive it if it's having a couple of hiccups. I guess it just means I'd better hurry up with the rebuild of the original engine block.
jules
Guitar Hero
Postby jules » Wed Mar 22, 2006 10:45 am
I was actually thinking valve stem seals at the time. It was at its worst when coming on the throttle after coasting on a downslope.
Not a fresh oil smell though, more of a smokey, powdery kind of smell. Black smoke as well. It's probably also running rich too I expect?
Jules
Return to “Queensland”
Users browsing this forum: No registered users and 41 guests
