Brisbane South. NB Turbo Installation 25-27th April
Queensland Events
Boags
Postby Boags » Thu May 08, 2008 3:07 pm
Have you got the car back yet??? 8)
Novice1
re turbo
Postby Novice1 » Mon May 12, 2008 7:13 pm
Figures are finally in 120 kw atw on 7 psi. Bit disappointing.
Tuners recommend I don't run
over 7 psi on stock internals, does this seem right ?
Would be interested in the relationship between boost increase and power
gained.
Cheers Novice1 aka Ron
Fatty
Re: re turbo
Postby Fatty » Mon May 12, 2008 7:17 pm
Novice1 wrote:Figures are finally in 120 kw atw on 7 psi. Bit disappointing.
gained.
120kw at 7psi sounds pretty good to me!
many people seem to run up to 12psi very safely, they are farely robust engines. limitting it to 7psi sounds ultra conservative to me.
jules
Guitar Hero
Re: re turbo
Postby jules » Mon May 12, 2008 8:33 pm
gained.
Ummm, I believe it's more like "boost increase = power gain. "
sabretooth
Re: re turbo
Postby sabretooth » Mon May 12, 2008 8:35 pm
gained.
That's pretty much spot on.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue May 13, 2008 9:13 am
it sounds like the tuner did not want to put the hard work in or is not farmiliar with the motor. there are plenty of guys running 15psi on the standard nb8b 10:1 comp motors and producing upwards of 260whp in the states. When running a reasonable amount of boost (probably up to about 15psi) the safety of the motor is all in the tune. The stock engine is pretty strong. What is your fuel system like? Maybe if you got a rising rate regular they might be a bit more comfortable with more boost. But I would say that you should be able to go up to 10psi with no troubles.
So with close to double stock hp how does it go?
Novice1
Postby Novice1 » Tue May 13, 2008 9:20 pm
16bit wrote:it sounds like the tuner did not want to put the hard work in or is not farmiliar with the motor. there are plenty of guys running 15psi on the standard nb8b 10:1 comp motors and producing upwards of 260whp in the states. When running a reasonable amount of boost (probably up to about 15psi) the safety of the motor is all in the tune. The stock engine is pretty strong. What is your fuel system like? Maybe if you got a rising rate regular they might be a bit more comfortable with more boost. But I would say that you should be able to go up to 10psi with no troubles.
Fuel system Walbro, 500cc injectors, 147.6kw atw, it goes like a shower of sh*T :)
Cheers Ron
JBT
Postby JBT » Tue May 13, 2008 11:02 pm
Better bring it out to the next track day then Ron for a good run. :D
Novice1
re turbo
Postby Novice1 » Wed May 14, 2008 7:50 pm
Had car de-boosted today to 132kw atw till I can get myself a stronger diff and a boost controller fitted.
Cheers Ron
Boags
Re: re turbo
Postby Boags » Wed May 14, 2008 7:51 pm
Novice1 wrote:Had car de-boosted today to 127kw atw till I can get myself a stronger diff and a boost controller fitted.
Cheers Ron
Don't worry about your diff; it's good for over 200KW if treated right.
How did they up the boost before?
Novice1
Re: re turbo
Postby Novice1 » Wed May 14, 2008 8:05 pm
Cheers Ron
Excuse my ignorance, but ?? bleed control valve.
Cheers Ron
Boags
Re: re turbo
Postby Boags » Wed May 14, 2008 8:20 pm
Novice1 wrote:
Cheers Ron
Cheers Ron
Yep, that sounds right. What do you mean by boost controller? A switch so you can have a "low boost" and "high boost" setting? 8)
Novice1
Dyno
Postby Novice1 » Thu May 15, 2008 8:05 am
Sorry for the poor quality photo. Will try and upload some other dynos
when I have more time.
Novice1
re turbo
Postby Novice1 » Sat May 24, 2008 1:32 pm
Just an update. I, have fixed the exhaust rattle, small oil leak around oil
return line fixed also. Fitted a cooling pro 52mm radiator last night.
Window tinting and better exhaust system next.
Cheers Ron
Return to “Queensland”
