Steampunk wrote:Come to think of it, last time it was only Apegrip and myself and we both went quite casually. I don't think we even did 70 when signed.
No braking at all. Didn't need to.
It was very enjoyable as it highlighted the ease with which you can drive MX-5s and maintain a somewhat enthusiastic pace.
Haven't done the run at night but I wouldn't describe myself as ever being more than 6 to 7 tenths up there. Generally rule is keep to the speed limit but try and do it everywhere (within reason). I think it's too variable an environment to push harder than that - the only time I've pushed harder was with a modified Soarer leading the way with around a 100 to 150 metre gap, so he would come across any issues first, but he was of a similar mindset in that he'd keep roughly to the limit (this was last year when it was predominantly 80) on the straights and push the corners.
You're spot on,though, it does underline the beauty of the MX-5 that you can sail through there close to the speed limit at an enthusiastic pace and have it be fun. Which for me was kind of the point. I had a late '90s Mirage that had had a bit of suspension work but no power mods that was hilarious up there - you could basically pin the throttle in third at The Gap and hold it flat for most of the run - sailed past the cops somewhere along the run right up the Mirage at about 15 km/h UNDER the limit.
I don't understand the mindset of the motorbikes pushing hard there and I've no doubt that's what's leading to the high fatality/injury rate amongst them up there. It just takes a half decent fallen branch, someone bringing gravel across the surface or a concealed wet patch and you're done.
The biggest fear for me would be to involve someone else in my accident if I did something stupid. Dunno if I could live with that.
