Power steering pump
Purfler
Power steering pump
Postby Purfler » Sat Sep 11, 2021 2:51 pm
My 1993 NA LE's power steering pump is starting to weep a bit - outrageous after only 28 years! I see the Mazda kits on ebay from the UK will cost about $90 delivered to Aus, but cannot find them locally. Does anyone know if they are available and at what price?
Thanks in advance.
Tim
1993 NA LE. 1968 Datsun 2000 Sports (SR311U) - in bits. Disclaimer: In this as in most other thing I have absolutely no idea what I'm talking about.
Re: Power steering pump
Postby 93_Clubman » Sun Sep 12, 2021 1:02 pm
Here's a local one at Keilor East for $65 pick-up or $80 delivered: https://www.ebay.com.au/itm/172805721695
However, you may want a kit from Mazda as the UK ones appear to be - this one's nearly half the price: https://www.autolinkmx5.com/power-steer ... 7231-p.asp
Before finding the above my suggestion was going to be check with a good local power steering business or Amayama: https://www.amayama.com/en or even your local Mazda dealer.
Purfler
Postby Purfler » Sun Sep 12, 2021 3:24 pm
Many thanks. I think I'd prefer the genuine Mazda kit. I'll try the local Mazda dealer - wonder if they do click and collect :-)
Tim
Postby 93_Clubman » Sun Sep 12, 2021 3:45 pm
Doubt the dealer will beat $35 for genuine Mazda parts from Amayama: https://www.amayama.com/en/part/mazda/n00232610
Btw, if you haven't already, probably worth confirming the PS pump is original.
Purfler
Postby Purfler » Mon Sep 13, 2021 7:24 pm
Thanks once again for the reply. I had ordered from Amayama after reading your previous post - I really didn't think I could get genuine parts for a better price and time isn't an issue:
1. because it has only just started a slight weep (haven't we all?)
2. If it has done 10km in the last few months I'd be amazed, and I don't think that's going to change (see above)
I hadn't thought of it not being original. It looks it (famous last words) and when I did the high pressure hose a couple years ago it all looked like it hadn't been touched since new.
Thanks again,
Tim
lonesailor
Postby lonesailor » Thu Sep 08, 2022 3:37 pm
Are you sure it's not justthe pump shaft seal?, you should be able to get the pump into a position to change the seal without undoing the lines. IF so, you should be able to take off the pully, pull out the seal using a pick or a self tapping screw, go to bearing supplies get a new seal( take the old one for a sample) and fit it, shouldn't take more than a couple of hours and cost around $10
Users browsing this forum: No registered users and 26 guests
